Myyty HyperX Alloy Origins Core TKL - Turku
30 and pick up for the G613:)
Need to cancel that, son won’t have it without rgb apparently.
Imagine how picky todays youth are.
How old is the G613? Perfectly working? I do have the same keyboard but very annoying double typing feature. Need to replace to working one.
I think it is about 2 years old, but has not been used much. If you are able to pick-up, maybe you can take it home and try before making the payment. :thumbsup:
I notice that you are from Tampere. I can test it for couple of days to make sure that the keys are ok and there is no double typing.
Shoutout for the seller.
Bought the Logitech keyboard,
Everything went as expected and the keyboard was very clean.
247 601
Staropramen
