Myyty HGST 600gb, 10krpm, 2.5" SAS-levyjä (TRE)
Myytävä tuote: HGST HUC109060CSS600, 600GB 10K SAS 2.5" HDD (12 kpl)
Hinta: 15 € / lätty, 5 kpl à 12,5 €.
Tuote ostettu (mistä ja milloin): Käytettynä.
Muuta huomioitavaa: Pyyhitty ja poistettu käytöstä toimivana.
HUOM
! Nämä ovat SAS-levyjä, eli eivät mene sellaisenaan kuluttajakoneisiin. Osta vain, jos tiedät tarvitsevasi SAS-levyjä.
Paikkakunta (ilmoita myös otsikossa): Tampere
Toimitustapa: Nouto tai postitus (ostaja vastaa postikuluista)
Maksutapa: Käteinen, tilisiirto.
Kuva:
=== START OF READ SMART DATA SECTION ===
SMART Health Status: OK
Current Drive Temperature: 40 C
Drive Trip Temperature: 85 C
Manufactured in week 51 of year 2014
Specified cycle count over device lifetime: 50000
Accumulated start-stop cycles: 18
Specified load-unload count over device lifetime: 600000
Accumulated load-unload cycles: 1874
Elements in grown defect list: 0
Error counter log:
Errors Corrected by Total Correction Gigabytes Total
ECC rereads/ errors algorithm processed uncorrected
fast | delayed rewrites corrected invocations [10^9 bytes] errors
read: 0 701436 9 0 8890375 310700.428 0
write: 0 10214340 0 0 463610 38680.177 0
verify: 0 21576 0 0 431918 100772.069 0
Non-medium error count: 229
No Self-tests have been logged
Background scan results log
Status: no scans active
Accumulated power on time, hours:minutes 44621:38 [2677298 minutes]
Number of background scans performed: 0, scan progress: 0.00%
Number of background medium scans performed: 0
Protocol Specific port log page for SAS SSP
relative target port id = 1
generation code = 4
number of phys = 1
phy identifier = 0
attached device type: SAS or SATA device
attached reason: unknown
reason: unknown
negotiated logical link rate: phy enabled; 6 Gbps
attached initiator port: ssp=1 stp=1 smp=1
attached target port: ssp=0 stp=0 smp=0
SAS address = 0x5000cca056c24179
attached SAS address = 0x5003005701ffda63
attached phy identifier = 7
Invalid DWORD count = 156
Running disparity error count = 142
Loss of DWORD synchronization = 37
Phy reset problem = 0
Phy event descriptors:
Invalid word count: 156
Running disparity error count: 142
Loss of dword synchronization count: 37
Phy reset problem count: 0
relative target port id = 2
generation code = 4
number of phys = 1
phy identifier = 1
attached device type: no device attached
reason: power on
negotiated logical link rate: phy enabled; unknown
attached initiator port: ssp=0 stp=0 smp=0
SAS address = 0x5000cca056c2417a
attached SAS address = 0x0
attached phy identifier = 0
Invalid DWORD count = 0
Running disparity error count = 0
Loss of DWORD synchronization = 0
Invalid word count: 0
Running disparity error count: 0
Loss of dword synchronization count: 0
E: Kaikkien pitäisi olla samaa erää, pieniä laitekohtaisia eroja. Levykohtaiset smartit saa pyytämällä (ja pienellä viiveellä).
Samaa erää myynnissä myös muualla.
Oranta
