Ostettu GTX 1060 Blower fan - Vaasa
I'll write in english if it's alright as I'm finnishswedish and my finnish isn't the best, I understand it alright though.
Looking for a GTX 1060 (6gb preferably) that due to a small form factor build needs to be a blower fan model specifically, the length of the card for the same reason also needs to also be 25cm or under (most common ones seems to be just at 24.X cm or lower which is fine, but some very few models are longer), I can go to 27cm if I remove a fan but I'd preferably not do that.
I have a blower GTX 1060 (3gb) just measured and the length is 24cm
Managed to get a 6gb one from Tori, thank you for the offer though would have otherwise bought it probably.
247 427
Muropakolainen
