Myyty Google Coral USB Accelerator, EDGE TPU, Jyväskylä
Tuote: Coral USB EDGE TPU accelarator
Hinta: 65+postit
Tuote ostettu (mistä ja milloin): 3.11.2023, avaamaton paketti, jäi yli
Kuitti löytyy (takuu voimassa): Kuitti löytyy, 2v EU takuu
Muuta huomioitavaa: Itse käytän AI tunnistuksissa esim Frigate. Potkua löytyy mukavasti. Myytävänä myös muualla.
The Coral USB Accelerator adds an Edge TPU coprocessor to your system, enabling high-speed machine learning inferencing on a wide range of systems, simply by connecting it to a USB port.
Performs high-speed ML inferencing​
The on-board Edge TPU coprocessor is capable of performing 4 trillion operations (tera-operations) per second (TOPS), using 0.5 watts for each TOPS (2 TOPS per watt). For example, it can execute state-of-the-art mobile vision models such as MobileNet v2 at almost 400 FPS, in a power efficient manner. See more performance benchmarks.
Supports all major platforms​
Connects via USB to any system running Debian Linux (including Raspberry Pi), macOS, or Windows 10.
Supports TensorFlow Lite​
No need to build models from the ground up. TensorFlow Lite models can be compiled to run on the Edge TPU.
ML acceleratorGoogle Edge TPU coprocessor:
4 TOPS (int8); 2 TOPS per watt
ConnectorUSB 3.0 Type-C* (data/power)
Dimensions65 mm x 30 mm
Paikkakunta (ilmoita myös otsikossa ja tagissa): Jyväskylä
Toimitustapa: Nouto, posti
Maksutapa: Käteinen , mobile, tilisiirto Screenshot 2024-12-21 210329.png
Snah182
