$ sudo fio-status -a
Found 2 ioMemory devices in this system with 1 ioDrive Duo
Driver version: 3.2.16 build 1731
Adapter: Dual Controller Adapter
Fusion-io ioDrive2 Duo 2410GB MLC, Product Number:7F6JV, SN:US07F6JV7605143P0007
ioDrive2 Adapter Controller, PN:F4K5G
SMP(AVR) Versions: App Version: 1.0.31.0, Boot Version: 0.0.8.1
External Power: connected
PCIe Bus voltage: avg 12.02V
PCIe Bus current: avg 1.78A
PCIe Bus power: avg 21.44W
PCIe Power limit threshold: Disabled
PCIe slot available power: 75.00W
PCIe negotiated link: 8 lanes at 5.0 Gt/sec each, 4000.00 MBytes/sec total
Connected ioMemory modules:
fct0: Product Number:7F6JV, SN:1403D03A4-1121
fct1: Product Number:7F6JV, SN:1403D03A4-1111
fct0 Attached
SN:1403D03A4-1121
SMP(AVR) Versions: App Version: 1.0.25.0, Boot Version: 0.0.9.1
Located in slot 1 Lower of ioDrive2 Adapter Controller SN:1403D03A4
Powerloss protection: protected
PCI:04:00.0
Vendor:1aed, Device:2001, Sub vendor:1028, Sub device:1f71
Firmware v7.1.15, rev 110356 Public
1205.00 GBytes device size
Format: v500, 2353515625 sectors of 512 bytes
PCIe slot available power: 25.00W
PCIe negotiated link: 4 lanes at 5.0 Gt/sec each, 2000.00 MBytes/sec total
Internal temperature: 43.31 degC, max 43.31 degC
Internal voltage: avg 1.01V, max 1.01V
Aux voltage: avg 2.48V, max 2.48V
Reserve space status: Healthy; Reserves: 100.00%, warn at 10.00%
Active media: 100.00%
Rated PBW: 17.00 PB, 79.54% remaining
Lifetime data volumes:
Physical bytes written: 3,477,590,129,734,584
Physical bytes read : 2,395,114,635,767,256
RAM usage:
Current: 824,797,760 bytes
Peak : 824,797,760 bytes
Contained VSUs:
fioa: ID:0, UUID:bf5a8bc5-c52a-4ac6-810b-d9766eba1deb
fioa State: Online, Type: block device
Format: 2353515625 sectors of 512 bytes
fct1 Attached
SN:1403D03A4-1111
Located in slot 0 Upper of ioDrive2 Adapter Controller SN:1403D03A4
PCI:05:00.0
Internal temperature: 42.33 degC, max 42.33 degC
Internal voltage: avg 1.01V, max 1.02V
Rated PBW: 17.00 PB, 79.63% remaining
Physical bytes written: 3,462,301,743,482,976
Physical bytes read : 2,379,685,022,064,792
RAM usage:
Current: 827,106,560 bytes
Peak : 827,106,560 bytes
Contained VSUs:
fiob: ID:0, UUID:1507cef6-c8bf-4f46-8153-1c9385a8f098
fiob State: Online, Type: block device
