FPS loss ja stuttering -ongelmia
Hei,
Minulla on ollut mystisiä FPS loss ja stuttering -ongelmia viimeisen kuukauden ajan. Olen kysellyt apua Redditin puolella, mutta ongelma ei vielä ole ratkennut. Täältä olen saanut aiemmin hyvää apua, joten tässä alkuperäinen postaukseni redditiin (englanniksi, koska olen liian laiska kääntämään koko tekstiä):
So I recently posted here to ask whether my GPU is faulty and got a great response that suggested that I change the thermal paste in the GPU. I did that and temperaturewise everything is great now, but I'm still experiencing a problem with performance and am now asking for help to identify the issue and its root.
I mainly play Apex Legends, Rainbow Six: Siege and Teamfight Tactics (League of Legends). A little less than a month ago I started experiencing FPS loss and stutters here and there. It's not constant and happens in places that don't really follow any consistent logic to my eye.
For instance, whenever the whole map is in front of my eyes in Apex Legends in the jumpship, I never have any FPS loss or stutter, but when I get down and run or move, I get them in random places. Smoke and fog effects sometimes also cause noticeable little loss in framerate. With Apex its more the stutters that is the issue and they happen even when I lower my settings.
Rainbow Six: Siege performs mostly very good, but I have framerate loss here and there and a small stutter here and there as well.
Teamfight Tactics has only low framerate and happens when a lot is going on, but I didn't used to have this issue with the game. That's the issue in general: I didn't used to have these issues with any other game than Apex Legends that I've had stutters in for quite a long time now. The stutters and frameskips also used to happen in World of Warcraft.
My question is: what is the cause of these kinds of issues in general? Fast googling says that it's when the computer isn't good enough to run games, but my computer should be and has been good enough for quite a few years now with the same games. The next question is: what can be done about it?
I've uninstalled and reinstalled my GPU drivers quite a few times with the help of DDU now and taken the GPU physically out of the computer quite a few times as well and put it back in. One of the weirdest instances was when I took the card out and put it back in and saw massive FPS loss in Apex. Did the same again and everything went back to normal. I had everything the exact same way both times.. cords connected, GPU in PCI-E slot as usual and so on, but for some reason experienced this issue. Ever since that I haven't been able to get back to not have FPS loss and stutters and it's killing me as my computer is still pretty good.
Any help is very appreciated!
Setup:
i7-9700K
RTX 2080 Super
16 GB RAM
Z390-H Gaming
Sen verran vielä lisäisin tähän, että League of Legendsiä pelatessani minulla on FPS counter näkyvissä ja vaikka FPS-luvut ovat aikalailla yhtä hyviä kuin ennenkin, peli alkaa näyttää lähempänä 140 fps:ää samalta kuin jos jokin peli pyörii backgroundissa alemmalla frameratella. Tätä ei myöskään ole tapahtunut aiemmin.
Korjataanpa tänne, että stuttering on väärä termi, mitä olen tässä käyttänyt. Kyse on frameskipeistä, ei stutterista.
Ongelma myöskin jatkuu formatoinnin jälkeen. Testasin koneessa vanhempaa 1070 -korttia ja sama ongelma ilmeni myös sillä. Ainoat komponentit, jota en vielä ole koittanut, ovat prosessori, muisti ja kovalevyt.
Tällä voi selvittää eri virkistystaajuuksilla onko ongelma näytössä, puhelimesta vaan manuaalisesti tuon valotusajan säädät ja otat kuvan.
8 säiettä on aika hidas tietokone nykymittapuulla. Mikä sinulla on tuossa jäähynä?
Kirjoitit että olet asentanut ajurit uusiksi. Mutta oletko kokeillut vanhempia ajureita ?
Kun Nvidian ajureita on vaivannut viimeaikoina ihme ongelmat mitkä esim aiheuttaa määrätyissä peleissä että frametime ovat ihan mitä sattuu.
Ja jonkun takia joka toisia ajureita tämä ongelma on vaivannut ja joka toisia ei.
532.03 ajurit toimi ainakin ilman ongelmia ja taas esim. 531.79 oli näitä ongelmia.
Että kokeileppa noita 532.03 ajureita.
EDIT: Tästä vielä linkki noihin 532.03 ajureihin: GeForce 532.03 WHQL driver download
Tarkista rasituslämmöt hwinfo64:lla. Gpuz näyttää toimiiko pcie täydellä x16 3.0-kaistalla.
henksel
Make ATK Great Again
Minulla oli aikanaan oman koneen kanssa hieman samankaltainen ongelma.
Eli vaikka fps oli korkea, lämmöt maltilliset ja näennäisesti kaikki oli ok, niin pelit tuntuivat nykivältä ja epätasaiselta.
Syyksi paljastui lopulta hiiren ajureista 125 Hz polling rate, eli hiiren päivitystaajuus oli selvästi matalampi kuin pelin/näytön kuvataajuus -> liikkuminen ja tähtääminen tuntui kummalliselta.
Ehkä hieman kaukaa haettu ratkaisu, mutta tarkistamisen arvoinen.
Ajoin eilen Memtestin, joka antoi useampia erroreita. Tänään hain uudet muistit ja errorit ovat nyt poissa, mutta frameskippejä ja fps lossia tapahtuu silti edelleen.
Kraken X52. Prosessorin ja sen jäähdytyksen kanssa ei muita ongelmia ole ollut kuin kosketushäiriö tosiaan johdossa.
Voisinpa nuo ajurit vielä tsekkailla. Olen nyt asentanu toisiksi uusimmat ajurit, koska ne ovat olleet stabiileimmat. Uusimmilla frameskipit lisääntyvät huomattavasti ja kolmanneksi uusimmilla stutterit Rainbow Six: Siegessä olivat täysin sietämättömät. En muista numeron perusteella, mihin nuo linkkaamasi aikajanalla sijoittuvat, mutta jos johonkin aiemmin, niin testaan niitä. Kiitos.
Edit: 532.03 ajurit jotakuinkin yhtä stabiilit kuin 536.23 ... frameskipit Apexissa alkavat aina jonkin ajan päästä. Niitä ei ole hirveästi, mutta aina välillä ja suhteellisen satunnaisissa paikoissa. FPS lossia en erityisemmin pelissä huomaa.
Rasituslämmöt täysin ok:t sekä CPU:lla että GPU:lla. Vaihdoin juuri tahnat GPU:hun yksien neuvojen myötä.
Oman hiireni polling rate on 1000hz ainakin Razer Synapsessa. Hiiren firmwaren voisin tietty päivittää.
Edit: Lisättäköön, että olen koittanut myös emolevyn toista PCI-E -porttia GPU:lle ja tulos oli sama myös sillä.
Nostanpa tämän vielä päivittääkseni tilannetta, koska apu olisi edelleen kovasti tarpeen.
Ongelmat jatkuvat edelleen, pelistä riippuen ne ovat erilaisia. League of Legendsin kanssa ongelmana on frameraten alhaisuus tai oikeammin se, että peli näyttää pyörivän alemmilla frameilla, kuin pelin oma counter kertoo. Se näkyy ajoittain omituisen nykivänä grafiikkana, joka osuu silmään. Apex Legendsin kanssa frameskipit ovat jatkuvia ja nyt en ole saanut asennettua ajureita, joilla frameskipit eivät olisi niin häiritseviä, että peli on lähes pelikelvoton, koska niitä tapahtuu niin usein (ei kuitenkaan koko ajan). Apexin kanssa grafiikka-asetusten muuttaminen pienemmäksi ei vaikuta asiaan mitenkään, skipit ovat yhtä tiheitä huolimatta asetuksista. Hämmentävästi itse pelin sulavuuteen ongelma ei muuten Apexissa vaikuta... frameskippien välissä peli näyttää hyvältä ja yhtä sulavalta kuin ennenkin. Tökkiminen tapahtuu satunnaisissa paikoissa vailla erityistä logiikkaa omaan silmääni. Jumpshipissä lennettäessä normaalisti kaikki on sulavaa, mutta viimeisillä parilla kerralla, jos pyöritän kameraa nopeasti ympäri, tapahtuu heti tökkimistä hetken aikaa ja sitten se taas loppuu.
Olen nyt kokeillut myös XMP -profiilin disabloimista, mutta tulos on täysin sama. Uudet muistit ostin tosiaan viime viikolla, mutta vaikutus on pyöreä nolla, vaikka uudet muistit eivät enää memtestissä erroreita annakaan.
Käytännössä ainoat komponentit, joista ei ole varmuutta, ovat emolevy ja prosessori. Näytönohjain on edelleen pieni mahdollisuus, mutta testasin tosiaan yhdessä kohtaa vanhalla 1070:llä ja frameskippejä tapahtui edelleen Rainbow Six: Siegessä ainakin. Testasin myös toista PCI-E -väylää ja sama tulos.
En tiedä, onko virtalähde millään tapaa mahdollinen ongelman lähde, koska satunnaisia sammumisia ja muita ei kone tee.
Todella toivoisin jonkinlaista neuvoa siihen, mistä suurimmalla todennäköisyydellä ongelma johtuu, että tietäisin, mitä komponenttia lähden paikkaamaan, että saisin vaan koneen toimimaan normaalisti, koska tämä alkaa tehdä minut hulluksi.
Uusimman biosin sekä piirisarjan voisi varmistaa emon tukisivulta, siis että ne on asennettu. Vaikka iäkäs cpu, ainakin varmistaa tuon. Ne ja puhdas Gpu- ajuri sulkee ainakin ajuripuolen pois.
Vaikea enää muuta keksiä, olet jo laajalti kokeillut kaikenlaista. 3dmarkin ja esim. cpu-testin sieltä voisi ehkä ajaa ja verrata vastaavan kokoonpanon pisteisiin cpu ja gpu-scorea. Testithän piirtää myös käppyrää käyttöasteesta, tosin eihän nuo testit pitkiä ole. Mutta katsoisin löytyykö jotain outouksia tuota kautta, käyrien tasaisuuksissa ja pistemäärissä yleisesti.
Pääsisi ehkä jyvälle liittyykö cpu:hun vai gpu:hun.
Koska kyseessä näyttää olevan ilmeisesti vain nettipelit niin mites tuo nettiyhteys? Olisiko siinä jotain?
No tänään asensin uudelleen tuon vanhan 1070:n kiinni ja League of Legendsissä tuota "puolittuneiden framejen" efektiä tule, vaikka framerate tippuukin alemmas. Peli pysyy kuitenkin sulavana koko ajan. Syy siis todennäköisesti GPU:ssa lopulta. Olen kovin hämmentynyt vain, että mikä ongelman on aiheuttanut (tahnat toki olisi selkeästi pitänyt vaihtaa paljon ennemmin) ja miksi Siegessä edelliskerralla testatessa ilmeni sillä myös frameskippejä. Jatkan testausta nyt vielä, mutta näyttää nyt todennäköisemmältä se, missä syy mahdollisesti on.
Jokin taustaprosessi tekee kiusaa? Itse huomasin (epä?)satunnaista nytkähtelyä kun pidin jotain Aida64:ää tai hwmonitoria päällä pelatessa, kun halusin hetken seurata uuden koneen lämpöjä yms. Tapa kaikki turha taustalta hetken testiä varten. Mukaan lukien GeForce Experience, jos sellaista on laitettu.
Itse asiassa pari päivää sitten päätin koittaa ottamalla kaikki käynnistyksen yhteydessä käynnistyvät non-Microsoft servicet pois päältä ja low and behold, Apexin frameskipit katosivat sen jälkeen kokonaan. Jotain outoa kuitenkin on edelleen menossa, sillä FPS tipahduksia tapahtuu silti edelleen ja kahdella ruudulla pyörittäessä peli+stream tahmaa jotenkin, mutta en osaa sanoa miten. Ihan kuin framet kärsisivät molemmilla (ei tapahtunut aiemmin). Ongelma ilmenee edelleen molemmilla näytönohjaimilla.
Kokeilepa pudottaa biosista PCI-E gen3:sta gen2 modeen. Pitäisi riittää 1070:lle enemmän kuin hyvin, itsellä korjasi mystisen stutterointiongelman.
Jos windows 11 käytössä niin otappa pois päältä ytimen eristäminen ja muistin eheys, voi auttaa asiaan. Vaihtoehtoisesti prossun virtualisointi pois päältä bioksesta.
248 273
jpaulamaki
