Myyty Emotiva Stealth DC-1 DAC
Myytävä tuote: Emotiva Stealth DC-1 DAC. Huippulaite jäänyt ylimääräiseksi.
Hinta: 400e
Muuta huomioitavaa: Tarkat speksit alla
  • Frequency Response
    20 Hz to 20 kHz + / - 0.1 dB @ 44.1k sample rate
    20 Hz to 40 kHz + / - 0.1 dB @ 96k sample rate
    20 Hz to 70 kHz + / - 0.1 dB @ 192k sample rate
  • THD+N
    0.00033% or less @ all sample rates
  • IMD (SMPTE)
    0.0025% typical
  • S/N Ratio
    95 dB @ all sample rates; 16 bit word length
    115 dB @ all sample rates; 24 bit word length
  • Headphone Amplifier Output Power (from digital sources):
    2.5 VRMS max into 10 Ohms @ < 0.01% THD (625 mW)
    7.1 VRMS max into 47 Ohms @ < 0.02% THD (1070 mW)
    7.26 VRMS max into 100 Ohms @ < 0.02% THD (525 mW)
    7.32 VRMS max into 300 Ohms @ < 0.02% THD (175 mW)
    7.35 VRMS max into 600 Ohms @ < 0.02% THD (90 mW)
  • Headphone Amplifier Output Power (from analog input):
    (note: 2.5 VRMS analog input required for full output into 47 ohms or higher)
    2.5 VRMS max into 10 Ohms @ < 0.003% THD (625 mW)
    7.1 VRMS max into 47 Ohms @ < 0.003% THD (1070 mW)
    7.2 VRMS max into 100 Ohms @ < 0.006% THD (510 mW)
    9.23 VRMS max into 300 Ohms @ < 0.004% THD (280 mW)
    9.27 VRMS max into 600 Ohms @ < 0.007% THD (140 mW)
  • Input Connectors
    One pair unbalanced analog audio (consumer level); gold plated solid machined RCA
    One AES/EBU digital audio (XLR)
    Three S/PDIF digital audio (1 x RCA, 1 x BNC, 1 x Toslink optical)
    One USB digital audio input (“type B” USB connector; UAC2)
  • Output Connectors
    One pair balanced analog audio (pro level; +6 dBV); XLR
    Two headphone connectors, front panel (2 x 1/8” stereo “mini”)
  • USB Audio
    Stealth DC-1 appears to computer as “USB audio device”
    UAC2 drivers required (provided) for computers running Windows (XP, Vista, 7, 8)
  • Power Source
    115 VAC or 230 VAC; manually switched (switch on bottom of chassis)
    Power consumption: approximately 15 watts
    Standard IEC AC power inlet on rear panel
    (Removable / interchangeable power cord; included.)
    Main AC Power rocker switch on rear panel
    Fuse: 20mm x 5mm; 1 A / 250 V fast acting; T1AL250V (internal)
  • Size and Weight
    Size: 1.75” high x 8.5” wide x 10” deep (including connectors and knobs).
    Weight: 2.2 pounds (1 kg)
Sijainti: Helsinki
Toimitustapa: Nouto / postitus
Maksutapa: Tilisiirto / Mobilepay
245 867
AzzA
