Myydään DIGITUS 2.5 Gigabit Ethernet Server Network Card - 4 Port (H:ki)
Tuote: Verkkokortti DIGITUS 2.5Gb, 4 porttia
Hinta: 50 €
Tuote ostettu (mistä ja milloin): 12/2024 Amazon
Kuitti löytyy (takuu voimassa): Kuitti löytyy
Muuta huomioitavaa: Uuden veroinen
Toimitustapa: Nouto / postipaketti
Maksutapa: MobilePay / käteinen
Toimii Proxmox:in kanssa.
Technical details:
  • Support PCI Express Specification Revision 2.1, 2-Lane PCI Express bus connecting with up to 10Gbps bus width
  • PCI Express interface: x4
  • Integrated 10M BASE-Te and 100/1000M/2.5G base-T 802.3 compatible transceiver
  • Supports 2.5G and 1G Lite mode
  • Auto-Negotiation with Extended Next Page capability(XNP)
  • Supports pair swap/polarity/skew correction, Crossover Detection& Auto-Correction
  • Supports 1-Lane 2.5/5Gbps PCI Express Bus
  • Supports hardware ECC(Error correction code)function, Supports hardware CRC(Cyclic Redundancy Check)function
  • Supports PCI MSI (Message Signaled Interrupt)and MSI-X
  • Transmit/Receive on-chip buffer support
  • Supports ECMA-393 ProxZzzy Standard for sleeping hosts, Wake-On-LAN and ‘RealWow!’ Technology (remote wake-up)supports
  • Compatible with IEEE802.3,IEEE802.3u,IEEE802.3ab
  • Supports IEEE1588v1,IEEE1588v2,IEEE80.2AS time synchronization
  • Supports IEEE802.1Qav credit-based shaper algorithm
  • Supports IEEE802.1P Layer 2 Priority encoding
  • Supports IEEE802.1Q VLan tagging
  • Supports IEEE802.1ad Double VLAN
  • Supports IEEE802.3az (Energy Efficient Ethernet)
  • Supports IEEE802.3bz(2.5GBase-T)
  • Supports full duplex flow control(IEEE802.3x)
  • Supports jumbo frame to 16K bytes
  • Supports Virtual Machine Queue(VMQ), Supports quad core Receive –Side Scaling(RSS)
  • Supports Protocol Offload (ARP&NS)
  • Drivers for Vista /Win7 / Win8 / Win10 /Win11/ Sever2008 / Sever 2012 / Linux / DOS
  • Chipset: RTL8125B+ASM1806
J3rb4
