- Liittynyt
- 02.12.2016
- Viestejä
- 2 023
Myytävä tuote: Celestra VA 250 high-end autovahvistin
Hinta: 600e
Tuote ostettu (mistä ja milloin): Käytettynä muutama vuosi sitten
Kuitti löytyy (takuu voimassa): Ei, ei.
Italialaista käsityötä. OVH 1500 euroa, Celestra VA250 High End Amplifier - Audiostatus
Ulkoisesti joitain naarmuja, muutoin hyvässä kunnossa. Virtajohdot mukaan.
2x 50Wrms nominal power 200Wrms bridged nominal power into 4 Ohm
Idle current 1.2A
17A max at nominal power into 4 Ohm
THD: less than 0.1% until 1 clipping (20hz t0 20 khz)
Frequency response: -3 Db at 8hz and more than 400khz at nominal power into 4 ohm
Input impendance: 10Kohm
Stereo separation: 80Db at 1 Khz
Signal to noise ratio: >120 Db linear (20 hz to 20 Khz)
Dimensions: 242x295x66 mm 4.5kg
Speakers fully separate from amplification circuit (total feedback = 0).
Input stage with class A jfet.
Polycarbonat capacitors onto signal path.
RCA cinch with teflon insulator.
Power output stage with case TO247 powerMOS for best heat dissipation.
Power output stage in AAB class, without switch in power devices (non-switching devices).
Heavy and massive speaker connectors to allow great cable size.
500W DC @12V high frequency switching power supply with virtual battery ultra fast recovey system.
Massive silver power battery connectors with very low contact resistance.
Tri-mode operation (mono+stereo).
No any current limiter, in order to do not clamp requested peak output current.
Massive aluminum heatsink tunnel devices, with integrated and auto-regulated fans for full power running also at high ambient temperatures.
Paikkakunta (ilmoita myös otsikossa): Eura
Toimitustapa: Nouto, posti
Maksutapa: Käteinen, mobilepay
Kuva:
![IMG_2112.jpeg IMG_2112.jpeg](https://bbs.io-tech.fi/data/attachments/757/757653-440a69f4ac445bd1ab1ed97a286c5c1f.jpg)
Hinta: 600e
Idle current 1.2A
Kuva:
![IMG_2109.jpeg IMG_2109.jpeg](https://bbs.io-tech.fi/data/attachments/757/757650-245605bd4d14f2b1d28b209f00e89f4f.jpg)
![IMG_2110.jpeg IMG_2110.jpeg](https://bbs.io-tech.fi/data/attachments/757/757651-80069759bdbbfb87fda7f9b8c155798c.jpg)
![IMG_2111.jpeg IMG_2111.jpeg](https://bbs.io-tech.fi/data/attachments/757/757652-6a605cb1f5f6c87bffb9353e71b22b9a.jpg)
