BSOD coldbootissa
Moi,
Ongelma on se, että aina kun kone on ollut pari vuorokautta käyttämättä ja boottaa, niin tulee memory management bsod.
Osat: 10700kf, g.skill sniper 3200mhz (2x8gb), Tuf z590, strix 2080ti.
Minidump:
MEMORY_MANAGEMENT (1a)
# Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 0000000000061941, The subtype of the BugCheck.
Arg2: 0000015297422120
Arg3: 0000000000000009
Arg4: ffffad8b075b7390
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 1702
Key : Analysis.DebugAnalysisManager
Value: Create
Key : Analysis.Elapsed.mSec
Value: 4514
Key : Analysis.Init.CPU.mSec
Value: 796
Key : Analysis.Init.Elapsed.mSec
Value: 69696
Key : Analysis.Memory.CommitPeak.Mb
Value: 126
Key : WER.OS.Branch
Value: vb_release
Key : WER.OS.Timestamp
Value: 2019-12-06T14:06:00Z
Key : WER.OS.Version
Value: 10.0.19041.1
FILE_IN_CAB: MEMORY.DMP
BUGCHECK_CODE: 1a
BUGCHECK_P1: 61941
BUGCHECK_P2: 15297422120
BUGCHECK_P3: 9
BUGCHECK_P4: ffffad8b075b7390
PROCESS_NAME: Registry
STACK_TEXT:
ffffad8b`075b71e8 fffff805`52c44454 : 00000000`0000001a 00000000`00061941 00000152`97422120 00000000`00000009 : nt!KeBugCheckEx
ffffad8b`075b71f0 fffff805`52c0545e : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!MmAccessFault+0x1a54c4
ffffad8b`075b7390 fffff805`52ecc2a2 : fffff805`52deb4e4 00000000`00000060 00000000`0000002d ffffad8b`00000000 : nt!KiPageFault+0x35e
ffffad8b`075b7528 fffff805`52deb4e4 : 00000000`00000060 00000000`0000002d ffffad8b`00000000 00000000`00000000 : nt!HvpGetCellPaged+0xa2
ffffad8b`075b7530 fffff805`52e9612a : 00000000`00000008 00000000`00000000 00000000`00000000 00000000`00000001 : nt!CmQueryValueKey+0x284
ffffad8b`075b7690 fffff805`52c08cb5 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!NtQueryValueKey+0x5ba
ffffad8b`075b7990 00007fff`57fcd054 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x25
00000000`008ce9c8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007fff`57fcd054
MODULE_NAME: hardware
IMAGE_NAME: hardware_ram
STACK_COMMAND: .cxr; .ecxr ; kb
FAILURE_BUCKET_ID: 0x1a_61941_PAGE_TABLE_RESERVED_BITS_SET_IMAGE_hardware_ram
OS_VERSION: 10.0.19041.1
BUILDLAB_STR: vb_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {c6e5c6cf-692e-7852-5dc5-b74944540fc0}
Followup: MachineOwner
Onko muistit vaan vialliset, vai voiko jännitteillä yrittää fiksailla? Muistijännite, vccio, vccsa, tms?
Kun boottaa uudelleen kone toimii täysin normaalisti ja vakaasti.
Jännitettä voi koittaa toki 1.37 -1,4v. Kokeneemmat voi auttaa jos ei tuolla pelitä. Jännä tuo kylmäkäynnistys, jos se vaikka treenaa muisteja alussa ja sitten ei ensimmäisellä kerralla onnistu.
Virtalähdekin on testattu niin, jotta johto on irrotettu useammaksi tunniksi. Ei vaikutusta.
Mikä virtalähde?
Muistit tarvitsee aikaa lämmetä, ja tämä voi johtua ihan niistä muisteista, emolevystä tai virtalähteestä. Todennäköisimmin vika on muisteissa, mutta voi niitä muitakin katsella. Laita myös FAST BOOT pois päältä, niin se ainakin treenaa ne muistit :)
Thermatake madrid 850w, 80 plus gold. Ei ole mikään huippu varmastikaan, mutta pitäis olla riittävä. Jännitteet ei notkahtele, vaikka olis prossu ja näyttis 100% rasituksessa yhtäaikaa.
Tämä tais ratketa. Kaiken mahdollisen kokeilun jälkeen viimeisimmän bsod:n ollessa - page fault in nonpaged area - vaihdoin kasperskyn aviraan, koska minidumpissa viittaus ko. ohjelmaan ja samalla asetin kiinteän sivutiedoston.
Ei sittenkään tuo auttanu. Muutaman onnistuneen coldbootin jälkeen tuli uudestaan memory management bsod. Laitailin memtest 86 ja virhettähän sieltä hetken päästä puski. Nyt sitte muistivoltteja säätämällä 1.29:ään ajettu memtest läpi 4 kertaa onnistuneesta. Yksi testi oletusasetuksilla vajaa kolme tuntia. Tuntuu todella kummalliselta, että alhaisemmilla jännitteillä vakautuu. Onko kenelläkään mitään ajatuksia? Muistien vaihtoa mietin, mutta jos toimii noin, niin en tiedä onko järkevää. Eipä tosiaan ainakaan noita muisteja tarvi kellotella, kun paskoo alleen, jos nostaa jännitettä.
248 295
Jeffersson
