Myyty Borderlands 3 PC latauskoodi (EPIC Launcheriin)
Myytävä tuote: Borderlands 3
Hinta: 20 euroa
Muuta huomioitavaa: Koodi tullut RX 570 näyttiksen mukana, mutta ei itselle tarvetta. Ei tarvitse enää AMD prossua/näyttistä vaan suora koodi Epic Launcheriin.
This guide will walk through the steps of redeeming a code through the Epic Games Launcher. Codes can also be redeemed through epicgames.com in a similar way.
  1. Open the Epic Games Launcher. If you have not downloaded and installed the Epic Games Launcher, you can do so from epicgames.com
  2. Click on your Epic Games account Display Name in the bottom left corner. This will open your account settings menu
  3. Click “Redeem Code”
  4. Enter your 20-digit code.
  5. Confirm the product you’re redeeming a code for and click “Redeem”
  6. Navigate to your Library by clicking the “Library” button on the left side of the screen.
  7. Confirm that you received the product in your Library
Sijainti: Tampere
Toimitustapa: YV / Sposti
Maksutapa: Tilisiirto / Siirto / Mobilepay
kunsokea
