Vaihdettu Asus poseidon 1080TI+Asus ROG Swift PG278Q gsync 1440P 144hz 27" > AMD+Freesync QHD monitor
Jonimoisio
BANNATTU
BANNED
Just curious if anyone is up for a trade.
The screen works Flawless(no dead pixels or anything) and so does the card.
With the poseidon I can also send a Ek-phoenix 240mm radiator with integrated pump+fittings.
There is 2 months warranty i belive still on the gpu but no warranty left on the screen :)
If you have a 5700/XT or a Radeon VII with a freesync QHD screen and want to go green team maybe we can do a swap?
If someone with an air cooling solution 1080ti wants to go water/air i maybe willing to make a trade to another 1080ti.
80 celcius in benchmarks on air around 48-53 with water.
Reason I want to change is because I can't fit it with my radiator in the case :)
Can also sell the card for the right price.
I'm located in turku and face to face deal is a must :)
Best of regards
Joni
Arpa Nex
