Ostetaan AM4 mATX emolevy + Ryzen 3000 series CPU
Tuote: AM4 mATX emolevy + Ryzen 3000 series CPU
Hinta: tarjo
Kuitti löytyy (takuu voimassa):
Muuta huomioitavaa: Tarvitsen AM4 emolevyä ja Ryzen 3000 sarjan prossun.
Toivottavasti englanti on hyväksyttävä täällä.
Basically, I want to explain my situation a little bit. Just yesterday, I had a fully functional computer. I found a Corsair CS650M for cheap, so I thought I would go and buy it to replace my CX600, seeing as it is semi-modular and slightly larger capacity. Win-win, I thought. Thing is, after I got the PSU from the seller and went home, I tested the PSU really quickly on an old computer whose components I had lying around, and it seemed to work just fine, so I removed my old PSU and put in the new one. Once everything was connected, though, I flipped the switch on the PSU, saw the RGB lights on the side of my motherboard light up, pressed my computer case's power button...and nothing. Well, not technically nothing; the CPU cooler fan and the case fans turn on, but the GPU fans don't turn on anymore, and the CPU (an ASUS TUF B550M-Plus) shows a red CPU light (it has a row of Q-LED indicators labelled with DRAM, CPU, VGA and BOOT). The CPU, for context, is a Ryzen 5 5600. I re-connected my old PSU (that just yesterday had worked, so I knew it wasn't the PSU being broken) and...same thing, red CPU light. I tried re-flashing the BIOS (as you have to do this for Zen 3 CPUs on B550 motherboards manufactured before a certain date, which mine is; I had already done this process before so no problem, right?), but this did not help. I also cleared the CMOS battery, nothing. Re-flashed BIOS again after clearing CMOS battery, nothing. Replaced CMOS battery, nothing.
I am at my wit's end right now, and the two solutions I can try at this point, I guess, is either find a Zen 2 CPU, so I can confirm that my current CPU is the problem and not have to worry about what BIOS version it is when I test it, or get a new motherboard. Maybe I am missing something, but it seems to me either my CPU or my motherboard is malfunctioning, so I am open to any (cheap) Zen 2 CPUs and/or any B550 (or B450, I guess) mATX motherboards (or ATX if anybody can also offer a very cheap and/or free case to go along with it, but my own case currently is an mATX case, so I would prefer that).
tl;dr: I think my motherboard and/or CPU was somehow broken by a PSU swap, so I need a cheap Zen 2 CPU and/or a compatible motherboard to see if my motherboard or CPU might be at fault.
P.S. If somebody would be willing to borrow and/or come over to my place and/or let me come over to their place with any compatible components (Zen 2 or Zen 3 CPU, an AM4 motherboard) so I can troubleshoot these components, then that would be amazing, but I know that is a lot to ask from a stranger; so additionally, if anybody knows any kind of a repair place in Helsinki where I could go with my motherboard and/or CPU and find out if either of them are faulty, then that would also be great.
Sorry for the wall of text, I am just scrambling for solutions right now to a time-sensitive problem. Also, sorry if all this information is in "the wrong section" or whatever, just thought it was all relevant to the ad in general.
Toimitustapa: F2F
Maksutapa: Käteinen, MobilePay
248 306
ramushe
