- Liittynyt
- 01.02.2021
- Viestejä
- 80
![www.aquatuning.com](https://aquatuning.shop-cdn.com/media/image/18/2b/86/1012140_13uPmQJomvxGgP..jpg)
WAC Alphacool Eisbaer (Solo) - 2600rpm - black
The Eisbaer Solo is a combination of CPU cooler, pump and expansion tank with G1/4" connections. Build your own CPU AIO cooler.
![www.aquatuning.com](https://aquatuning.shop-cdn.com/media/image/8f/c4/18/1013299_1oV0Q0a2ve0D93..jpg)
ROH Alphacool Eisbaer GPX Extension Set (tubes and fittings)
Alphacool Eisbaer GPX Extension Set! For your water cooling
It works well and the accessories are in the original package. The paint chipped off from certain fittings when trying to untighten it from the system but it is not visible. I have an extra brand new "Fill"' fitting that I can give for free. I got a deal from Proshop for a water-cooled GPU so I bought these parts to use it with it. I later transitioned to custom-water cooling but Eisbaer worked well in a system of CPU+ GPU+420mm radiator well enough. Used for 6-7 months.
Price altogether is 50 EUR
9 X Barrow 90 degree fittings
![www.aliexpress.com](https://ae01.alicdn.com/kf/Sbb55d79c30734bb2ab5dd26d01d2190fY/Barrow-90-Degree-Rotary-Fitting-TWT90-V2-5-Matte-Silver-Angled-Connector-PC-Gaming-Water-Cooling.jpg)
2.52€ 76% OFF|Barrow 90 Degree Rotary Fitting TWT90 V2.5 Matte Silver Angled Connector PC Gaming Water Cooling Building Accessories| | - AliExpress
Smarter Shopping, Better Living! Aliexpress.com
3 EUR per item
3 X Aphacool 140mm Pure Wings 2 Fan PWM
20 EUR
Toimitustapa: Nouto
Maksutapa: Mobilepay, Cash
Kuva:
240,4 KB Katsottu: 33
312,2 KB Katsottu: 31
263,2 KB Katsottu: 29
