- Liittynyt
- 06.04.2017
- Viestejä
- 1 056
Myytävä tuote: 5x Crucial MX500 1TB SSD
Hinta: 50€/kpl tai 270€ kaikki + postituskulut
Tuote ostettu (mistä ja milloin): Tarkastan kun löyvvän kaikkiin kuitit muuttokuorman seasta.
Muuta huomioitavaa: Varastolevyinä olleet, mutta jääneet tarpeettomaksi.
Etusijalla koko kasa > noudolla > useemman levyn ottaja.
Alla SMART infot
Paikkakunta (ilmoita myös otsikossa ja tagissa): Oulu (Koskela)
Toimitustapa: Nouto, posti
Maksutapa: MobilePay, tilisiirto
Kuva:
![ssd.jpg ssd.jpg](https://bbs.io-tech.fi/data/attachments/1107/1107184-64afcce93b67da7976078d226a676805.jpg)
Alla SMART infot
Koodi:
smartctl 7.3 2022-02-28 r5338 [x86_64-linux-6.2.12] (local build)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Crucial/Micron Client SSDs
Device Model: CT1000MX500SSD1
Serial Number: 2108E4FD3D08
LU WWN Device Id: 5 00a075 1e4fd3d08
Firmware Version: M3CR033
User Capacity: 1 000 204 886 016 bytes [1,00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
TRIM Command: Available
Device is: In smartctl database 7.3/5319
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Fri Jun 2 13:08:17 2023 EEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x80) Offline data collection activity
was never started.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 0) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 30) minutes.
Conveyance self-test routine
SCT capabilities: (0x0031) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 100 100 000 Pre-fail Always - 0
5 Reallocate_NAND_Blk_Cnt 0x0032 100 100 010 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 2518
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 385
171 Program_Fail_Count 0x0032 100 100 000 Old_age Always - 0
172 Erase_Fail_Count 0x0032 100 100 000 Old_age Always - 0
173 Ave_Block-Erase_Count 0x0032 098 098 000 Old_age Always - 41
174 Unexpect_Power_Loss_Ct 0x0032 100 100 000 Old_age Always - 50
180 Unused_Reserve_NAND_Blk 0x0033 000 000 000 Pre-fail Always - 18
183 SATA_Interfac_Downshift 0x0032 100 100 000 Old_age Always - 0
184 Error_Correction_Count 0x0032 100 100 000 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
194 Temperature_Celsius 0x0022 068 025 000 Old_age Always - 32 (Min/Max 0/75)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_ECC_Cnt 0x0032 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 100 100 000 Old_age Always - 0
202 Percent_Lifetime_Remain 0x0030 098 098 001 Old_age Offline - 2
206 Write_Error_Rate 0x000e 100 100 000 Old_age Always - 0
210 Success_RAIN_Recov_Cnt 0x0032 100 100 000 Old_age Always - 0
246 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 17325283853
247 Host_Program_Page_Count 0x0032 100 100 000 Old_age Always - 142044358
248 FTL_Program_Page_Count 0x0032 100 100 000 Old_age Always - 350375693
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Completed [00% left] (0-65535)
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Koodi:
Serial Number: 2108E4FD3E41
LU WWN Device Id: 5 00a075 1e4fd3e41
was never started.
been run.
command.
power-saving mode.
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 2526
173 Ave_Block-Erase_Count 0x0032 098 098 000 Old_age Always - 39
180 Unused_Reserve_NAND_Blk 0x0033 000 000 000 Pre-fail Always - 22
246 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 17296645149
247 Host_Program_Page_Count 0x0032 100 100 000 Old_age Always - 141716480
248 FTL_Program_Page_Count 0x0032 100 100 000 Old_age Always - 325103087
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
Koodi:
Serial Number: 2108E4FD3D00
LU WWN Device Id: 5 00a075 1e4fd3d00
was never started.
been run.
command.
power-saving mode.
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 2356
173 Ave_Block-Erase_Count 0x0032 098 098 000 Old_age Always - 43
180 Unused_Reserve_NAND_Blk 0x0033 000 000 000 Pre-fail Always - 20
194 Temperature_Celsius 0x0022 069 028 000 Old_age Always - 31 (Min/Max 0/72)
246 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 19211122917
247 Host_Program_Page_Count 0x0032 100 100 000 Old_age Always - 156816941
248 FTL_Program_Page_Count 0x0032 100 100 000 Old_age Always - 375674917
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
Koodi:
Serial Number: 2213E620FB83
LU WWN Device Id: 5 00a075 1e620fb83
Firmware Version: M3CR043
was never started.
been run.
command.
power-saving mode.
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 2993
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 341
173 Ave_Block-Erase_Count 0x0032 099 099 000 Old_age Always - 16
174 Unexpect_Power_Loss_Ct 0x0032 100 100 000 Old_age Always - 17
180 Unused_Reserve_NAND_Blk 0x0033 000 000 000 Pre-fail Always - 58
194 Temperature_Celsius 0x0022 072 043 000 Old_age Always - 28 (Min/Max 20/57)
202 Percent_Lifetime_Remain 0x0030 099 099 001 Old_age Offline - 1
246 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 9690009282
247 Host_Program_Page_Count 0x0032 100 100 000 Old_age Always - 81745597
248 FTL_Program_Page_Count 0x0032 100 100 000 Old_age Always - 91232201
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
Koodi:
Serial Number: 2213E620ABF0
LU WWN Device Id: 5 00a075 1e620abf0
was never started.
been run.
command.
power-saving mode.
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 3020
173 Ave_Block-Erase_Count 0x0032 099 099 000 Old_age Always - 15
174 Unexpect_Power_Loss_Ct 0x0032 100 100 000 Old_age Always - 16
180 Unused_Reserve_NAND_Blk 0x0033 000 000 000 Pre-fail Always - 63
194 Temperature_Celsius 0x0022 070 046 000 Old_age Always - 30 (Min/Max 20/54)
246 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 9684836146
247 Host_Program_Page_Count 0x0032 100 100 000 Old_age Always - 82034870
248 FTL_Program_Page_Count 0x0032 100 100 000 Old_age Always - 87339039
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
Koodi:
Serial Number: 2108E4FD3CDD
LU WWN Device Id: 5 00a075 1e4fd3cdd
was never started.
been run.
command.
power-saving mode.
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 2521
173 Ave_Block-Erase_Count 0x0032 098 098 000 Old_age Always - 36
180 Unused_Reserve_NAND_Blk 0x0033 000 000 000 Pre-fail Always - 26
194 Temperature_Celsius 0x0022 068 023 000 Old_age Always - 32 (Min/Max 0/77)
246 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 17304621717
247 Host_Program_Page_Count 0x0032 100 100 000 Old_age Always - 141198226
248 FTL_Program_Page_Count 0x0032 100 100 000 Old_age Always - 291738315
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
Kuva:
