Ostettu 40 pin IDE cable
Hi guys,
I am in need of a 40 pin IDE cable for an old machine of mine. The cable must be at least 30cm long and it must not have any "keyed" pins, so in other words all 40 pins must be visible on the connectors. Name your price if you have one, I would like it posted to Espoo if possible or I can come to get it if you are happy with that and you live locally. Thanks!
Hi! It is the right kind of cable but unfortunately it has the "keyed" pin that is blocked - so it's of no use to me I'm afraid. Thanks anway :)
247 577
FransH
