Myyty 2x4TB WD RE 7200rpm
levyt myynnissä: Myydään - 2x4TB WD RE 7200rpm
Myytävä tuote: NASsina toiminut tietokone/palvelin seuraavilla spekseillä:
uNAS NSC-800 ITX & NAS-kotelo kahdesalla hotswapattavalla kovalevytelineellä (U-NAS NSC-800 Server Chassis) Kaikki kelkat (8kpl) on tallella.
Supermicro A1SRi-2758F
32GB ECC DDR3 SODIMM
120GB Kingson SSD (SV300S37A120G)
LSI SAS9211-8I
2x4TB WD RE (RE, ei RED, takuuta jäljellä myös vajaa pari vuotta)
Aspower U1A-C20400-D 400W virtalähde
Hinta: hp. 800€
Tuote ostettu (mistä ja milloin): ebay
Muuta huomioitavaa: Hyvin kasattu, ilmesesti "Datto DN6000" kyseessä
Myydään 2x4TB WD RE 7200rpm levyt
Hinta: hp. 150€
Smartit levyille:
smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: SandForce Driven SSDs
Device Model: KINGSTON SV300S37A120G
Serial Number:
LU WWN Device Id: 5 0026b7 75904cdb9
Firmware Version: 605ABBF1
User Capacity: 120,034,123,776 bytes [120 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS, ACS-2 T13/2015-D revision 3
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sat Nov 3 08:28:05 2018 PDT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 0) seconds.
capabilities: (0x7d) SMART execute Offline immediate.
No Auto Offline data collection support.
Abort Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 48) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x0025) SCT Status supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x0032 120 120 050 Old_age Always - 0/0
5 Retired_Block_Count 0x0033 100 100 003 Pre-fail Always - 0
9 Power_On_Hours_and_Msec 0x0032 082 082 000 Old_age Always - 16270h+50m+26.560s
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 22
171 Program_Fail_Count 0x000a 100 100 000 Old_age Always - 0
172 Erase_Fail_Count 0x0032 100 100 000 Old_age Always - 0
174 Unexpect_Power_Loss_Ct 0x0030 000 000 000 Old_age Offline - 19
177 Wear_Range_Delta 0x0000 000 000 000 Old_age Offline - 1
181 Program_Fail_Count 0x000a 100 100 000 Old_age Always - 0
182 Erase_Fail_Count 0x0032 100 100 000 Old_age Always - 0
187 Reported_Uncorrect 0x0012 100 100 000 Old_age Always - 0
189 Airflow_Temperature_Cel 0x0000 031 038 000 Old_age Offline - 31 (Min/Max 19/38)
194 Temperature_Celsius 0x0022 031 038 000 Old_age Always - 31 (Min/Max 19/38)
195 ECC_Uncorr_Error_Count 0x001c 120 120 000 Old_age Offline - 0/0
196 Reallocated_Event_Count 0x0033 100 100 003 Pre-fail Always - 0
201 Unc_Soft_Read_Err_Rate 0x001c 120 120 000 Old_age Offline - 0/0
204 Soft_ECC_Correct_Rate 0x001c 120 120 000 Old_age Offline - 0/0
230 Life_Curve_Status 0x0013 100 100 000 Pre-fail Always - 100
231 SSD_Life_Left 0x0000 071 071 011 Old_age Offline - 120259084288
233 SandForce_Internal 0x0032 000 000 000 Old_age Always - 116138
234 SandForce_Internal 0x0032 000 000 000 Old_age Always - 113183
241 Lifetime_Writes_GiB 0x0032 000 000 000 Old_age Always - 113183
242 Lifetime_Reads_GiB 0x0032 000 000 000 Old_age Always - 23156
244 Unknown_Attribute 0x0000 069 069 010 Old_age Offline - 61735854
SMART Error Log not supported
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Myös destruktiivinen badblocks (-ws) ajettu levyille, ei löydettyjä bad sectoreita.
Sijainti: pk-seutu
Toimitustapa: posti,mh ym
Maksutapa: tili,mobilepay,siirto jne
myynnissä myös muualla
Kuva: Myöhemmin, kotelo on hyvässä kunnossa, ei mitään silmään pistäviä jälkiä.
Laitetaan tänne vielä tasaraha, eli hp. 800€ ja 650€ ilman levyjä.
up! Vielä löytyy! Laitetaan lisähinnoitteluna emolevy+muistit+LSI SAS9211-8I hintaan 450€ Koppaa en myy ilman muita osia erikseen.
Ostetaan pois ilman levyjä hintaan 650 EUR jos kaikki osat ovat tosiaan moitteettomassa kunnossa!
Asun itse Espoossa, aika lähellä Helsinkiä. Voisi harkita noutoa/toimitusta. Jatketaan varmaan YV:llä?
247 220
Peppi
