Myyty 2TB verkkolevyjä + NVMe PCIe adapteri [Joensuu]
  • Keskustelun aloittaja Keskustelun aloittaja Err
Err
Myynnissä muutama 2TB verkkolevy järeämmän setin alta.
-Buffalo LinkStation Live HS-DHGL v2
Sisälle on vaihdettu WDC WD20EARX-19PASB0 levy.
Koodi:
Device Model:     WDC WD20EARX-19PASB0
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   174   163   021    Pre-fail  Always       -       6266
  4 Start_Stop_Count        0x0032   099   099   000    Old_age   Always       -       1266
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   074   074   000    Old_age   Always       -       19412
 10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   099   099   000    Old_age   Always       -       1211
192 Power-Off_Retract_Count 0x0032   199   199   000    Old_age   Always       -       926
193 Load_Cycle_Count        0x0032   001   001   000    Old_age   Always       -       1688716
194 Temperature_Celsius     0x0022   120   100   000    Old_age   Always       -       30
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   200   200   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
HP: 35€
-Seagate Central 2TB Myyty!
Alkuperäinen paketti löytyy.
Koodi:
Device Model:     ST2000VM003-1CT164
  1 Raw_Read_Error_Rate     0x000f   118   099   006    Pre-fail  Always       -       193537952
  3 Spin_Up_Time            0x0003   096   095   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   053   053   020    Old_age   Always       -       48205
  5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   065   060   030    Pre-fail  Always       -       3255129
  9 Power_On_Hours          0x0032   073   073   000    Old_age   Always       -       24168
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       24
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
189 High_Fly_Writes         0x003a   094   094   000    Old_age   Always       -       6
190 Airflow_Temperature_Cel 0x0022   054   043   045    Old_age   Always   In_the_past 46 (0 19 56 37)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       39
193 Load_Cycle_Count        0x0032   076   076   000    Old_age   Always       -       48205
194 Temperature_Celsius     0x0022   046   057   000    Old_age   Always       -       46 (0 16 0 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
HP: 40€
Ja sitten pari WD MyCloudia joiden sisälle on vaihdettu 2TB WD RE4-GP-levyt. Kyseiset levyt oli myyty minulle aikanaan uutena, mutta jotenkin uskon että näistä on vain SMART-data nollattu new old stockin sijaan. Eli pientä varausta näiden levyjen kanssa, parit kappaleet jouduin lähettämään aikanaan takaisin myyjälle. Ota vaikka projektiksi pyörittämään Debiania!
WD MyCloud 1: Myyty!
Koodi:
Device Model:     WDC WD2003FYPS-27Y2B0
  3 Spin_Up_Time            0x0027   230   223   021    Pre-fail  Always       -       10500
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       198
  9 Power_On_Hours          0x0032   099   099   000    Old_age   Always       -       1045
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       174
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       85
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       112
194 Temperature_Celsius     0x0022   117   100   000    Old_age   Always       -       35
HP: 55€
-WD MyCloud 2 Myyty!:
Koodi:
  3 Spin_Up_Time            0x0027   232   224   021    Pre-fail  Always       -       10383
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       189
  7 Seek_Error_Rate         0x002e   100   253   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   099   099   000    Old_age   Always       -       1067
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       168
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       78
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       110
194 Temperature_Celsius     0x0022   114   102   000    Old_age   Always       -       38
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       1
HP: 55€
-Sitten vielä matala NVMe M.2 adapteri PCIe 16x väylään, oli käytössä kuukauden verran mutta vaihdoin tilalle toisen adapterin paremmalla jäähdytyksellä.
HP: 14€ Myyty!
Tarjota saa!
Sijaintina Joensuu.
Toinen noista wd cloudeista 60 sis postit?
HP: 14€
10€ posteineen?
Eemeli77
