Myyty 180€! QNAP QSW-1208-8C 4xSFP++ 8 x 10 gbe rj45 10G-Base-T / 8xsfp+ combo kytkin, Porvoo
Tuote: QNAP QSW-1208-8C 4xSFP+ 8 x 10 gbe rj45/8xsfp+ combo kytkin
Hinta: 180€, uutena 900+€
Tuote ostettu (mistä ja milloin): 2018 kaupasta
Toimiva kytkin toimintatakuulla
Räkkiraudat mukana
The QNAP QSW-1208-8C is a 12-port 10GbE unmanaged switch, allowing you to instantly upgrade your network environment at a cost-effective price. The QSW-1208-8C supports 10GBASE-T and NBASE-T standards, allowing you to take advantage of higher network speeds with your existing Cat 5e and 6a cables. Both SFP+ (fiber) and RJ45 (copper) ports are available (with 8 combo ports) for servicing a range of network needs. With high performance, low latency and superb functionality, the QSW-1208-8C is the ideal choice for upgrading your home or business network to support 10GbE connections. The QSW-1208-8C is made in Taiwan (MIT), providing a high-quality and reliable networking solution.
Paikkakunta (ilmoita myös otsikossa ja tagissa): Porvoo
Toimitustapa: nouto/posti
Maksutapa: mobilepay/tilisiirto/käteinen
ateks
