Call of Duty: Warzone (F2P Battle Royale PC/PS4/XB1)
Juu meinasi oikein suu loksahtaa auki, kun tuota kohtaa luin. Parantaako ne oikeesti hiirellä tähtäävien asemaa tässä pelissä? Ei kai? Seuraava ajatus sitten olikin, että ohjainpelaajat eli enemmistö rupeaa tuosta valittamaan ja koko uudistus otetaan kohta pois tai sitä ainakin lievennetään. Nautitaan kun voidaan.
Resurgence ranked tuntui muuten ihan hyvältä, mutta tuota karttaa ei selvästi ole kovin hyvin onnistuttu optimoimaan suorituskyvyn osalta. Freimit droppailee jatkuvasti alle 100 fps samoilla asetuksilla, joilla isossa kartassa pysyy 140-150.
Reactions: TML
Call of Duty: Warzone Season 2 Patch Notes
Friday, February 16, 2024
https://www.callofduty.com/patchnotes/2024/02/call-of-duty-mwiii-warzone-season-2-patch-notes
Weapon Adjustments
» Light Machine Gun «
  • TAQ Evolvere
    • Fixed a bug that caused limited recoil while using the base weapon.
    • 7.62 Ammunition
      • Max Damage reduced to 40, down from 45.
      • Max Damage Range reduced to 36.83 meters, down from 40.64.
      • Near-Mid Damage Range reduced to 49.53 meters, down from 53.34.
      • Neck Damage Modifier reduced to 1.2x, down from 1.3x.
      • Upper Torso and Upper Arm Damage Modifiers reduced to 1.2x, down from 1.3x.
      • Upper Leg Damage Modifier reduced to 1.0x, down from 1.1x.
    • 5.56 Ammunition (100 & 200 Round 556 Belts)
      • Max Damage reduced to 28, down from 30.
      • Max Damage Range reduced to 18.03 meters, down from 20.32.
      • Headshot Damage Modifier reduced to 1.2x, down from 1.3x.
      • Neck, Upper Torso and Upper Arm Damage Modifiers reduced to 1.1x, down from 1.2x.
      • Lower Arm Damage Modifier reduced to 1.0x, down from 1.2x.
      • Near-Mid Damage increased to 25, up from 22.
      • Near-Mid Damage Range reduced to 30.48 meters, down from 50.8.
      • Added Mid Damage, set to 22. New Variable
      • Added Mid Damage Range, set to 45.72 meters. New Variable
      • Reduced ADS Movement Speed benefits by 10%.
      • Reduced Vertical Recoil by 40%.
Wednesday, February 21, 2024
Weapon Adjustments
» Assault Rifles «
  • MTZ 556
    • Decreased initial gun kick while firing.
    • Decreased recoil while firing.
    • Max Damage increased to 27, up from 25.
    • Max Damage Range increased to 35.56 meters, up from 24.13.
    • Near-Mid Damage increased to 24, up from 22.
    • Near-Mid Damage Range increased to 48.26 meters, up from 35.56.
    • Min Damage increased to 22, up from 20.
Taizuuni
Jai Bhole Ki!
S Y N T H W A V E
Juuh rankki nollaantunut, loadoutit ei toimi jne. SBMM taitaa myös olla rikki.
CODUpdates sanoi:
We're working on a fix for a known issue that appeared overnight that is preventing progress from being tracked in various areas of the game including but not limited to events, challenges, Battle Pass, and SR.
Players may also notice unusual behavior related to account level and loadouts.
Hitto miten paljon tässä pelissä on potentiaalia, mutta tälläsenään tulee aivan liian paljon WTF tilanteita vastaan :lol:
Serverit taitaa olla vielä 2000 luvun alkupuolella tickraten puolelta, konsolipelaajilla aivan liian hyvä aim assist käytössä ja sit se vit#%¤# hyppiminen :x3: Tekisi mieli mennä Activisionin nörtti toimistoon, lyödä pari telamiinaa roikkumaan, ase käteen ja pyytää hyppelemään :rofl:. Silti tulee kiltisti laitettua play nappulaa aivan liian useasti :x3:
Täysin samaa mieltä. Peli on pepusta, mutta pelattua tulee silti, kun ei vastaavaa/parempaakaan ole, jossa olisi laaja crossplay tuki. Ilmaisuus tässä on plussaa, mutta ei olisi mitenkään välttämättömyys jos peli olisi parempi
Näkyykö kenelläkään muulla Warzone Welcome Missions? Pitäisi olla START-painikkeen oikealla puolella.
Jos näkyy ja on hieman aikaa, niin voi saada helpohkoja tehtäviä tekemällä mm. Double Weapon XP tokeneita ja lopulta myös uuden Jabber Safeguard -skinin.
Minulla ne tehtävät tulivat näkyviin ilmeisesti sen jälkeen, kun olin käväissyt DMZ:ssa (en edes pelannut siellä).
Ja sitten sain tehtyäkin ne (PC, Steam).
Tehtäviä ei ole näkynyt kai kovinkaan monella ja tuon vinkin mukaan voisi tulla näkyviin DMZ:ssa käymällä (mutta vain Steam?).
Joo kyllähä tuosta voisi maksaa jos sitä kautta saataisiin vaikka serverit kuntoon.:thumbsup:
Eipä näy battle.net versiolla tuollaista valintaa, vaikka kävi DMZ:ssa pelissä. Joskus tosin muistaakseni pelasin tuollaisen silloin, kun se oli aiemmin näkyvillä
Call of Duty: Modern Warfare III and Call of Duty: Warzone Season 2 Reloaded Content Drop: What You Need to Know
https://www.callofduty.com/blog/2024/03/call-of-duty-modern-warfare-iii-warzone-season-2-reloaded-maps-modes-zombies-announcement
The Season 2 Reloaded mid-season update launches on March 6 at 9 AM PT across all platforms.
  • Two New Weapons: Slice up the competition with the Soulrender Melee weapon and dominate the mid-range with the SOA Subverter Battle Rifle.
  • New Killstreak: Clear out buildings of entrenched enemies with this aerial attack that decimates anyone within the targeted location.
  • New Field Upgrade: Create a safe zone in the gas with the Portable Decontamination Station, protecting any Operators within its area of effect.
Jos oli sinulla ollut aiemmin, niin ehkä siksi ei enää. En tiedä, miksi tulivat minulle. Olinko pelannut Warzonea riittävän vähän aikaa tai enkö ollut tehnyt joitakin kohtia tehtävistä koskaan? Buy back teammate oli kyllä minulle uusi juttu. Aloitin DMZ:n vuosi sitten ja muita, kuten Plunder (eniten), Lockdown ja Resurgence, aloin kokeilla vasta kun Modern Warfare III oli tullut.
Tässä ainakin tällä kertaa tarjolla olleet tehtävät, joista osa meni itsestään, kun vain kävi pelissä. :)
WARZONE WELCOME MISSIONS
BUY BACK TEAMMATE:a jouduin yrittämään useita kertoja, kun resurgencessa olin itse monesti se, joka olisi tarvinnut tuota... Tai jos joku kuoli, niin poistui pelistä kokonaan... Tai Buy station oli hankalassa paikassa. Kerran neljän pelaajan joukkueessa kukaan ei edes kuollut ja tuli sitten voittokin. Lopulta onnistui Fortune's Keep kartalla, kun kahdesta kuolleesta pelaajasta toinen jäi odottamaan ja buy station oli lähellä olleessa luolassa. :)
ADD FRIEND:n jätin viimeiseksi. Etsin jonkun viimeksi mukana olleista pelaajista. Lähetin friend rquestin. Kun näin, että uusi skini aktivoitui, niin sitten vain peruin sen requestin.
Friday, March 22, 2024
WEAPONS
» Battle Rifles «
  • BAS-B
    • JAK Outlaw-277 Kit
      • Increased rate of fire to 241rpm, up from 193rpm.
      • Decreased aim down sight rate of fire penalty to 150%, down from 300%.
      • Decreased rechamber time to 264ms, down from 330ms.
      • Removed 50% bullet velocity benefit.
      • Increased target flinch to 1 Newtons, up from 0.9N (+11%).
      • Increased incoming flinch to 0.23 Newtons, up from 0.17N (+35%).
    • Sawed Off Mod
      • Increased incoming flinch to 0.54 Newtons, up from 0.21N (+157%).
» Sniper Rifles «
  • Longbow
    • Modified controller aim assist properties to align with other Sniper Rifles.
    • Increased incoming flinch to 1 Newtons, up from 0.75N (+33%).
    • Increased target flinch to 1.7 Newtons, up from 0.8N (+113%).
BUG FIXES
  • Fixed an issue that allowed the Irradiated Perk to plate through any source of damage. It will now correctly only plate through gas damage.
Etsin esimerkkejä ja ohjeita, miten Warzone mobilea voisi pelata, jotta tietäisin, että kannattaako minun kokeilla.
Tässä kahdella peukalolla
Ja tässä kaksi peukaloa + etusormet (tabletilla ehkä enemmänkin sormia)
No, peukaloilla tietenkin! Ehkä peliohjaimella pelaaville tuo on helpompaa, mutta ainakin minä jatkan nuo nähtyäni tietokoneella (näppis+hiiri), kun pelkästään tuon katsominen tuntui peukaloissa...
Näin pidetään ja käytetään kännykkää. :) :)
Onko nyt tasan klo 19 alkanut palvelimet kellottamaan vai mistähän taas tulee? Estimate ei ainakaan pidä paikkaansa, kun ei vain pääse onlineen.
Tjaa. Kun painaa tuosta alta "mene offlineen", alkaa peli sentään lataamaan päivitystä.
Ensimmäistä kertaa myöntävät rehellisesti, että servut on alhaalla
April 3, 2024 7:13 PM PSTWe're currently experiencing connectivity issues. This incident is under investigation.
Joo, onhan ne taas melkosen kyykyssä.
Päivitys valuu välillä hulppeeta ~20kt/s ja tais vielä reilun ~15Gt olla ladattavaa eilisestä pre-loadista huolimatta.
Sen sijaan Steamiin latasi ihan normaalisti. Klo (noin) 19:15 alkaen latasi 30,3 gigaa vajaassa tunnissa (netin nopeus vajaa 100 Mbit/s ja parhaimmillaan tuli 11,9 Mt/s).
Call of Duty: Warzone Season 03 Patch Notes
Wednesday, April 10, 2024
https://www.callofduty.com/patchnotes/2024/04/call-of-duty-mwiii-warzone-season-3-patch-notes
:thumbsup:
WEAPONS
» Handguns «
  • Renetti
    • JAK Ferocity Carbine Kit
      • Max Damage decreased to 28, down from 36.
      • Min Damage decreased to 24, down from 28.
      • Max Damage Range decreased to 12.44 meters, down from 17.52.
      • Lower Torso Multiplier increased to 1.1x, up from 1.
      • Arms and Hand Multiplier increased to 1.1x, up from 1.
Tuesday, April 16, 2024
WEAPONS
» Assault Rifles «
  • MTZ-556
    • Increased bullet velocity to 690m/s, up from 650m/s .
  • Holger 556
    • Adjusted recoil and gun kick to decrease deviation, allowing a more predictable pattern.
  • M16 (MWII)
    • Decreased horizontal and vertical recoil by 20%.
    • Decreased gun kick by 20%.
    • Decreased visual recoil by 18%.
    • Note: Changes to the M16 were released before today’s game update.
» Submachine Guns «
  • RAM-9
    • Decreased minimum and maximum hipfire accuracy by 10%.
    • Increased aim down sight time to 220ms, up from 200ms.
  • Striker
    • Decreased aim down sight time to 204ms, down from 215ms.
    • Increased bullet velocity to 570m/s, up from 540m/s.
  • WSP Swarm
    • Decreased flinch resistance to 0.15N, down from 0.8N.
» Sniper Rifles «
  • MORS
    • Corrected an optic misalignment causing shots to travel slightly off-center.
Tässä päivityksen jälkeen niin onko muillakin tullut vastaan että lobbyt on ihan hirveitä tällaiselle perusjampalle pelata. Lähinnä Rankkia tulee pelattua PC:llä. Ei kerkiä silmiä saamaan auki kun nappi otsassa. Miten tässä oikein menee tämä matchmaking? Olisi kiva hyvällä idealla varustettua peliä pelata mutta alkaa moti menemään. Pingit, fps yms. hyvällä tasolla mutta tuntuu että vastustajat eivät kuole millään vaikka kuinka hernepyssyllä ammun selkään. Ja ei, en ole tulossa paremmaksi kun ihan huvikseni pelailen ja koitan pitää hauskaa mitä tämä peli välillä kyllä on. Lähinnä henkistä tukea etsin onko muutkin kokenut samaa viime aikoina että ihan mahdottomia servuja tulee vastaan. :D Voidaan perustaa vaikka tukiryhmä koska kohta mielensämenettäneitä on kasapäin. :lol:
I feel you bro :sheart::sbsmile:
Vähän samoja kokemuksia täälläkin, jossain platina 3 rankissa pelailen että ei mikään korkea edes ole. Välillä tulee lobbyjä missä tuntuu että nyt on suurinpiirtein samantasosia vastustajia mutta suurin osa kyllä on semmoista että ei vaan huvita pelata. Jotenkin tuo taso vaihtelee saman rankin pelaajien välillä todella paljon.
Itse en rankedia pelaa, mutta kavereiden kanssa ollaan pelattu alusta asti ja vasta nyt MW3 aikana on alkanut tämä sikailu, koodarit,247pelaajat,kiinalaiset yns
Taizuuni
Jai Bhole Ki!
S Y N T H W A V E
Huomaa kyllä että ajankohta vaikuttaa minkälaiseen lobbyyn joutaa. Arkena iltapäivällä pelit on melko haastavia, sit taas näin viikonloppusin tulee kyllä melko botti tason lobbyja vastaan.
Normi modessa näin, en tiedä miten tuolla resugencen puolella asiat menee.
Joo, itse pääasiassa tuota rankedia pelannut. Harmi että tuo pelaaminen on tuollaista, itse peli on kuitenkin viihdyttävä ja muutaman kaverin kanssa todella mukavaa ajanvietettä.
Season 3 Reloaded Patch Notes
Friday, May 3, 2024
GENERAL
The ongoing issue affecting automatic tactical sprint functionality, causing it to disrupt attempts to reload a weapon, is a top priority right now. Rest assured, our team is diligently working on implementing a solution, which we’re anticipating to release sometime next week. Thank you for your patience and understanding during this process.
WEAPONS
» Light Machine Guns «
  • DG-58 LSW
    • JAK Nightshade
      • Max Damage decreased to 30, down from 33.
      • Near-Mid Damage reduced to 27, down from 30.
      • Mid Damage reduced to 24, down from 28.
      • Max Damage Range decreased to 12.7 meters, down from 19.05.
      • Near-Mid Damage Range reduced to 24.13 meters, down from 30.48.
      • Headshot Modifier reduced to 1.15x, down from 1.4x.
» Marksman Rifles «
  • Lockwood MK2
    • JAK Wardens
      • Fixed an issue causing shots to not hit in the expected location while firing simultaneously.
BryciFani
BANNATTU
BANNED
Kellään muulla ei ole ollut mitään outoa pelin grafiikassa viime päivinä? Textuurit latautuu oudon hitaasti ja textuurien laatu huonontuntu ja väreissä jotain vikaa myös.
Mistä tämä helvetin paska johtuu:
Värit vituillaan ja textuurit vituillaan.
Ei ole tuollaista ongelmaa mutta viimeisimmän päivityksen jälkeen on tapahtunut semmoista että ei voi ladata asetta, kilpiä ei voi laittaa vaikka niitä olisi kannossa kuinka monta.
Myös pientä nykimistä esiintyy vähän väliä. Kaikki muut pelit toimivat ihan niinkuin ennenkin niin en oikein usko että johtuu omasta koneesta.
Taizuuni
Jai Bhole Ki!
S Y N T H W A V E
Tällä viikolla pitäisi tulla fixiä noihin tekstuuri, reload jne bugeihin. Tarkkaa päivää ei sanottu
Call of Duty: Warzone Season 3 Patch Notes
Wednesday, May 8, 2024
BUG FIXES
  • Fixed the issue causing automatic tactical sprint to interrupt attempts to reload a weapon.
  • Fixed an issue causing the Prioritize Interact setting on controllers to prevent players from reloading.
  • Fixed an issue preventing the host from starting a Private Match when over the player threshold.
  • Fixed an issue causing Squad members to see the incorrect ping on the Champion’s Quest contract.
Thursday, May 9, 2024
WEAPONS
» Marksman Rifles «
  • Lockwood MK2
    • JAK Wardens
      • Near-Mid damage increased to 26, up from 25.
      • Near-Mid damage increased range to 8.1 meters, up from 6.4.
      • Mid damage range increased to 20.3 meters, up from 16.3.
      • Increased standing hipfire spread minimum to 3.3deg/s, up from 2.3deg/s.
      • Increased standing hipfire spread maximum to 5.8deg/s, up from 5.5deg/s.
    • .410 Gauge Slug Shells Ammunition (JAK Wardens)
      • Added 21% standing hipfire spread minimum benefit.
      • Added 21% standing hipfire spread maximum penalty.
      • Resolved an issue where damage values were not applying as intended.
        • Max: 90 damage up to 7.6 meters
        • Near-Mid: 80 damage up to 15.7 meters
        • Mid: 70 damage up to 31.8 meters
        • Min: 50 damage up to elimination
    • .410 Gauge Ball Ammunition (JAK Wardens)
      • Decreased standing hipfire spread minimum benefit to 21%, down from 100%.
      • Decreased standing hipfire spread maximum benefit to 21%, down from 80%.
241 627
lolpasii
