user9999
Platinum-jäsen
- Liittynyt
- 17.10.2016
- Viestejä
- 3 057
Asuswrt-Merlin 3004.388.5 julkaistu (wifi 6 mallit).
3004.388.5 (2-Dec-2023)
- UPDATED: OpenSSL to 1.1.1w.
- UPDATED: Curl to 8.4.0.
- UPDATED: OpenVPN to 2.6.8.
- CHANGED: Enable fast-io for OpenVPN clients and servers that
use UDP, which will speed up performance on some models.
- CHANGED: You can now directly enter an IPv6 address on the
Network Tools page as a target.
- CHANGED: Display tracked connections on the QoS/Classification
page even if QoS isn't set to Adaptive QoS.
- CHANGED: QOS/Classification page can now resolve local IPv6
addresses.
- CHANGED: Allow custom MTU for Wireguard clients (patch from
Asus).
- FIXED: CIDR-formatted addresses were rejected on the Network
Filter page. Implemented temporary workaround.
- FIXED: Various issues with the QOS Classification page.
- FIXED: Netfilter TEE kernel module is missing.
- FIXED: OpenVPN client state getting cleared when Wireless
was being restarted.
- FIXED: Networkmap wasn't recognizing the GT-AX11000_PRO as
having USB 3.0 ports
Release - Asuswrt-Merlin 3004.388.5 is now available
Asuswrt-Merlin 3004.388.5 is now available for all supported Wifi 6 models. The focus of this release is component updates, bug fixes, and reworking the way the QOS Classification page works (solving various issues, and also making it works even when not using Adaptive QoS). 3004.388.5...
www.snbforums.com
addresses.
Asus).
