Vermon
Ph.D. in Wisdom Sciences
- Liittynyt
- 17.10.2016
- Viestejä
- 484
Ohops! Olivat menneet julkaisemaan jo X-Plane 11:n ja itse en huomannut mitään, paitsi nyt.
X-Plane on mielestäni paras lentosimulaattori, mitä tavan tallaajan ulottuvilla yleensäkkin on.
Oleellisimmat informaatiot copypastena:
"X-Plane is a flight simulator produced by Laminar Research. A desktop version is available for macOS, Windows, and Linux. X-Plane is packaged with several commercial, military, and other aircraft, as well as basic global scenery which covers most of the Earth.
X-Plane differentiates itself from other simulators by implementing an aerodynamic model called blade element theory. Traditionally, flight simulators emulate the real-world performance of an aircraft by using empirical data in predefined lookup tables to determine aerodynamic forces such as lift or drag, which vary with differing flight conditions.
With blade element theory, a surface (e.g. wing) may be made up of many sections (1 to 4 is typical), and each section is further divided into as many as 10 separate subsections. After that, the lift and drag of each section are calculated, and the resulting effect is applied to the whole aircraft. When this process is applied to each component, the simulated aircraft will fly similar to its real-life counterpart. This approach allows users to design aircraft quickly and easily, as the simulator engine immediately illustrates how an aircraft with a given design might perform in the real world. X-Plane can model fairly complex aircraft designs, including helicopters, rockets, rotorcraft, and tilt-rotor craft."
New in X-Plane 11:
Overhauled fleet
Aircraft models that stand up to scrutiny, from the gear trucks to the rivets.
3-D cockpits
Every aircraft in the fleet comes with a beautiful, usable 3-D cockpit.
IFR-ready cockpits
Every 3-D cockpit is usable for instrument flight.
Brand new user interface
Easier to learn for new users. Faster for power users.
Tutorials
Learn the basics of flight, navigation, & more in X-Plane.
Improved 3-D cockpit interaction
Cockpit controls are easier than ever to set just right.
Pushback tugs & fuel trucks
Watch other aircraft get service, or request services for your own aircraft.
New lighting, sound, & effects engine
Bringing new tools to aircraft add-on makers.
New scenery for Europe
Roadways, buildings, & more now feature European-specific variants.
X-Plane viralliset sivut: X-Plane 11 | Coming this holiday season.
X-Plane 11 Steamissa: X-Plane 11 on Steam
New in X-Plane 11:
Overhauled fleet
3-D cockpits
IFR-ready cockpits
Tutorials
