Videon koko nelin kertaistui Handbrakella
Timo 2
Premium-jäsen
eli kuten otsikossa lukee mulla kävi niin, että kun hanbrakella meinasin n. 10 GB kokoisen .ts muodossa olevan elokuvan kokoa pienentää ilman että laatu kärsii ja muuntaa .mkv muotoon hyödyntäen x265. onnistuin saamaan ulos 4 kertaa suuremman tiedoston, kuin alkuperäinen. eli jotain meni pieleen ja pahemman kerran.
HandBrake 1.3.3 (2020061300)
OS: Microsoft Windows NT 10.0.19041.0
CPU: AMD Ryzen 9 3950X 16-Core Processor
Ram: 16333 MB,
GPU Information:
AMD Radeon R9 200 Series - 26.20.15029.27017
Screen: 3840x2160
Temp Dir: C:\Users\käyttäjä\AppData\Local\Temp\
Install Dir: C:\Program Files\HandBrake
Data Dir: C:\Users\käyttäjä\AppData\Roaming\HandBrake
# Starting Encode ...
[11:34:07] base preset: H.265 MKV 2160p60 (Modified)
[23:34:07] hb_init: starting libhb thread
[23:34:07] Starting work at: Sat Sep 19 23:34:07 2020
[23:34:07] 1 job(s) to process
[23:34:07] json job:
"Audio": {
"AudioList": [
"Bitrate": 160,
"DRC": 0.0,
"Encoder": "av_aac",
"Gain": 0.0,
"Mixdown": 4,
"NormalizeMixLevel": false,
"Samplerate": 0,
"Track": 0,
"DitherMethod": 0
"CopyMask": [
"copy:aac",
"copy:ac3",
"copy:dtshd",
"copy:dts",
"copy:eac3",
"copy:flac",
"copy:mp3",
"copy:truehd"
"FallbackEncoder": "ac3"
"Destination": {
"ChapterList": [
"Name": "Chapter 1"
"ChapterMarkers": true,
"AlignAVStart": false,
"File": "U:\\Elokuvia\\Elokuva_ Beverly Hills Kyttä Ii (12) 2019.07.02 21.00-1.mkv",
"Mp4Options": {
"IpodAtom": false,
"Mp4Optimize": false
"Mux": "av_mkv"
"Filters": {
"FilterList": [
"ID": 4,
"Settings": {
"mode": "7"
"ID": 3,
"Settings": {
"block-height": "16",
"block-thresh": "40",
"block-width": "16",
"filter-mode": "2",
"mode": "3",
"motion-thresh": "1",
"spatial-metric": "2",
"spatial-thresh": "1"
"ID": 12,
"Settings": {
"crop-bottom": "106",
"crop-left": "8",
"crop-right": "0",
"crop-top": "58",
"height": "916",
"width": "1912"
"ID": 6,
"Settings": {
"mode": "1"
"PAR": {
"Num": 1,
"Den": 1
"Metadata": {},
"SequenceID": 0,
"Source": {
"Angle": 1,
"Range": {
"Type": "chapter",
"Start": 1,
"End": 1
"Title": 1,
"Path": "D:\\Elokuvia\\Elokuva_ Beverly Hills kyttä II (12) 2019.07.02 21.00.ts"
"Subtitle": {
"Search": {
"Burn": true,
"Default": false,
"Enable": true,
"Forced": true
"SubtitleList": []
"Video": {
"Encoder": "x265",
"Level": "auto",
"TwoPass": false,
"Turbo": false,
"ColorMatrixCode": 0,
"Options": "strong-intra-smoothing=0:rect=0:aq-mode=1",
"Preset": "placebo",
"Profile": "main",
"Quality": 5.0,
"QSV": {
"Decode": false,
"AsyncDepth": 0
[23:34:07] CPU: AMD Ryzen 9 3950X 16-Core Processor
[23:34:07] - logical processor count: 32
[23:34:07] Intel Quick Sync Video support: no
[23:34:07] hb_scan: path=D:\Elokuvia\Elokuva_ Beverly Hills kyttä II (12) 2019.07.02 21.00.ts, title_index=1
src/libbluray/disc/disc.c:323: failed opening UDF image D:\Elokuvia\Elokuva_ Beverly Hills kyttä II (12) 2019.07.02 21.00.ts
src/libbluray/disc/disc.c:424: error opening file BDMV\index.bdmv
src/libbluray/disc/disc.c:424: error opening file BDMV\BACKUP\index.bdmv
src/libbluray/bluray.c:2585: nav_get_title_list(D:\Elokuvia\Elokuva_ Beverly Hills kyttä II (12) 2019.07.02 21.00.ts\) failed
[23:34:07] bd: not a bd - trying as a stream/file instead
libdvdnav: Using dvdnav version 6.0.1
libdvdread: Encrypted DVD support unavailable.
libdvdread:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed
libdvdread:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.BUP failed
libdvdread: Can't open file VIDEO_TS.IFO.
libdvdnav: vm: failed to read VIDEO_TS.IFO
[23:34:07] dvd: not a dvd - trying as a stream/file instead
[23:34:07] file is MPEG Transport Stream with 188 byte packets offset 0 bytes
[23:34:07] Found the following PIDS
[23:34:07] Video PIDS :
[23:34:07] 0x515 type H.264 (0x1b) (PCR)
[23:34:07] Audio PIDS :
[23:34:07] 0x516 type MPEG1 (0x3)
[23:34:07] 0x517 type MPEG1 (0x3)
[23:34:07] Subtitle PIDS :
[23:34:07] Other PIDS :
[23:34:07] 0x518 type DVB Teletext (0x0)
[23:34:07] stream id 0x516 (type 0x3 substream 0x0) audio 0x516
[23:34:07] stream id 0x517 (type 0x3 substream 0x0) audio 0x517
[23:34:07] scan: decoding previews for title 1
[23:34:07] scan: audio 0x517: mp2, rate=48000Hz, bitrate=128000 Nederlands (MPEG) (2.0 ch) (128 kbps)
[23:34:07] scan: audio 0x516: mp2, rate=48000Hz, bitrate=128000 suomi (MPEG) (2.0 ch) (128 kbps)
[23:34:08] stream: 10 good frames, 0 errors (0%)
[23:34:08] scan: 10 previews, 1920x1080, 25.000 fps, autocrop = 58/106/8/0, aspect 16:9, PAR 1:1
[23:34:08] scan: supported video decoders: avcodec qsv
[23:34:08] libhb: scan thread found 1 valid title(s)
[23:34:08] Skipping subtitle scan. No suitable subtitle tracks.
[23:34:08] Starting Task: Encoding Pass
[23:34:08] work: only 1 chapter, disabling chapter markers
[23:34:08] job configuration:
[23:34:08] * source
[23:34:08] + D:\Elokuvia\Elokuva_ Beverly Hills kyttä II (12) 2019.07.02 21.00.ts
[23:34:08] + title 1, chapter(s) 1 to 1
[23:34:08] * destination
[23:34:08] + U:\Elokuvia\Elokuva_ Beverly Hills Kyttä Ii (12) 2019.07.02 21.00-1.mkv
[23:34:08] + container: Matroska (libavformat)
[23:34:08] * video track
[23:34:08] + decoder: h264
[23:34:08] + bitrate 200 kbps
[23:34:08] + filters
[23:34:08] + Comb Detect (mode=3:spatial-metric=2:motion-thresh=1:spatial-thresh=1:filter-mode=2:block-thresh=40:block-width=16:block-height=16)
[23:34:08] + Decomb (mode=39)
[23:34:08] + Framerate Shaper (mode=1)
[23:34:08] + frame rate: 25.000 fps -> constant 25.000 fps
[23:34:08] + Crop and Scale (width=1912:height=916:crop-top=58:crop-bottom=106:crop-left=8:crop-right=0)
[23:34:08] + source: 1920 * 1080, crop (58/106/8/0): 1912 * 916, scale: 1912 * 916
[23:34:08] + Output geometry
[23:34:08] + storage dimensions: 1912 x 916
[23:34:08] + pixel aspect ratio: 1 : 1
[23:34:08] + display dimensions: 1912 x 916
[23:34:08] + encoder: H.265 (libx265)
[23:34:08] + preset: placebo
[23:34:08] + options: strong-intra-smoothing=0:rect=0:aq-mode=1
[23:34:08] + profile: main
[23:34:08] + level: auto
[23:34:08] + quality: 5.00 (RF)
[23:34:08] + color profile: 1-1-1
[23:34:08] * audio track 1
[23:34:08] + decoder: suomi (MPEG) (2.0 ch) (128 kbps) (track 1, id 0x516)
[23:34:08] + bitrate: 128 kbps, samplerate: 48000 Hz
[23:34:08] + mixdown: Stereo
[23:34:08] + dither: none
[23:34:08] + encoder: AAC (libavcodec)
[23:34:08] + bitrate: 160 kbps, samplerate: 48000 Hz
[23:34:08] file is MPEG Transport Stream with 188 byte packets offset 0 bytes
[23:34:08] sync: expecting 204926 video frames
x265 [info]: HEVC encoder version 3.2.1+1-b5c86a64bbbe
x265 [info]: build info [Windows][GCC 9.2.0][64 bit] 8bit+10bit+12bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
x265 [info]: Main profile, Level-4 (Main tier)
x265 [info]: Thread pool created using 32 threads
x265 [info]: Slices : 1
x265 [info]: frame threads / pool features : 5 / wpp(15 rows)
x265 [info]: Coding QT: max CU size, min CU size : 64 / 8
x265 [info]: Residual QT: max TU size, max depth : 32 / 4 inter / 4 intra
x265 [info]: ME / range / subpel / merge : star / 92 / 5 / 5
x265 [info]: Keyframe min / max / scenecut / bias: 25 / 250 / 40 / 5.00
x265 [info]: Lookahead / bframes / badapt : 60 / 8 / 2
x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 1
x265 [info]: References / ref-limit cu / depth : 5 / off / off
x265 [info]: AQ: mode / str / qg-size / cu-tree : 1 / 1.0 / 32 / 1
x265 [info]: Rate Control / qCompress : CRF-5.0 / 0.60
x265 [info]: tools: rd=6 psy-rd=2.00 rdoq=2 psy-rdoq=1.00 tskip signhide tmvp
x265 [info]: tools: b-intra deblock sao
[23:34:08] sync: first pts audio 0x516 is 0
[23:34:08] sync: first pts video is 136586
[23:35:13] hb_init: starting libhb thread
# Starting Scan ...
[23:35:13] CPU: AMD Ryzen 9 3950X 16-Core Processor
[23:35:13] - logical processor count: 32
[23:35:13] Intel Quick Sync Video support: no
[23:35:13] hb_scan: path=D:\Elokuvia\Elokuva_ Beverly Hills kyttä III (12) 2019.07.03 21.00.ts, title_index=0
src/libbluray/disc/disc.c:323: failed opening UDF image D:\Elokuvia\Elokuva_ Beverly Hills kyttä III (12) 2019.07.03 21.00.ts
src/libbluray/bluray.c:2585: nav_get_title_list(D:\Elokuvia\Elokuva_ Beverly Hills kyttä III (12) 2019.07.03 21.00.ts\) failed
[23:35:13] bd: not a bd - trying as a stream/file instead
[23:35:13] dvd: not a dvd - trying as a stream/file instead
[23:35:13] file is MPEG Transport Stream with 188 byte packets offset 0 bytes
[23:35:13] Found the following PIDS
[23:35:13] Video PIDS :
[23:35:13] 0x515 type H.264 (0x1b) (PCR)
[23:35:13] Audio PIDS :
[23:35:13] 0x516 type MPEG1 (0x3)
[23:35:13] 0x517 type MPEG1 (0x3)
[23:35:13] Subtitle PIDS :
[23:35:13] Other PIDS :
[23:35:13] 0x518 type DVB Teletext (0x0)
[23:35:13] stream id 0x516 (type 0x3 substream 0x0) audio 0x516
[23:35:13] stream id 0x517 (type 0x3 substream 0x0) audio 0x517
[23:35:13] scan: decoding previews for title 1
[23:35:13] scan: audio 0x517: mp2, rate=48000Hz, bitrate=128000 Nederlands (MPEG) (2.0 ch) (128 kbps)
[23:35:13] scan: audio 0x516: mp2, rate=48000Hz, bitrate=128000 suomi (MPEG) (2.0 ch) (128 kbps)
hb_save_preview: Failed to open C:/Users/käyttäjä/AppData/Local/Temp/hb.18428/7_1_0 (reason: unknown error 2)
hb_save_preview: Failed to open C:/Users/käyttäjä/AppData/Local/Temp/hb.18428/7_1_1 (reason: unknown error 2)
hb_save_preview: Failed to open C:/Users/käyttäjä/AppData/Local/Temp/hb.18428/7_1_2 (reason: unknown error 2)
hb_save_preview: Failed to open C:/Users/käyttäjä/AppData/Local/Temp/hb.18428/7_1_3 (reason: unknown error 2)
hb_save_preview: Failed to open C:/Users/käyttäjä/AppData/Local/Temp/hb.18428/7_1_4 (reason: unknown error 2)
hb_save_preview: Failed to open C:/Users/käyttäjä/AppData/Local/Temp/hb.18428/7_1_5 (reason: unknown error 2)
hb_save_preview: Failed to open C:/Users/käyttäjä/AppData/Local/Temp/hb.18428/7_1_6 (reason: unknown error 2)
hb_save_preview: Failed to open C:/Users/käyttäjä/AppData/Local/Temp/hb.18428/7_1_7 (reason: unknown error 2)
hb_save_preview: Failed to open C:/Users/käyttäjä/AppData/Local/Temp/hb.18428/7_1_8 (reason: unknown error 2)
hb_save_preview: Failed to open C:/Users/käyttäjä/AppData/Local/Temp/hb.18428/7_1_9 (reason: unknown error 2)
[23:35:14] stream: 17 good frames, 0 errors (0%)
[23:35:14] scan: 10 previews, 1920x1080, 25.000 fps, autocrop = 0/0/0/6, aspect 16:9, PAR 1:1
[23:35:14] scan: supported video decoders: avcodec qsv
[23:35:14] libhb: scan thread found 1 valid title(s)
# Processing Scan Information ...
hb_read_preview: Failed to open C:/Users/käyttäjä/AppData/Local/Temp/hb.18428/7_1_1 (reason: unknown error 2)
# Scan Finished ...
[08:13:21] hb_init: starting libhb thread
# Starting Scan ...
[08:13:21] CPU: AMD Ryzen 9 3950X 16-Core Processor
[08:13:21] - logical processor count: 32
[08:13:21] Intel Quick Sync Video support: no
[08:13:21] hb_scan: path=D:\Elokuvia\Elokuva_ Pirates of the Caribbean_ Mustan helmen kirous (12) 2019.07.04 21.00.txt, title_index=5
udfread ERROR: ECMA 167 Volume Recognition failed
src/libbluray/disc/disc.c:323: failed opening UDF image D:\Elokuvia\Elokuva_ Pirates of the Caribbean_ Mustan helmen kirous (12) 2019.07.04 21.00.txt
src/libbluray/bluray.c:2585: nav_get_title_list(D:\Elokuvia\Elokuva_ Pirates of the Caribbean_ Mustan helmen kirous (12) 2019.07.04 21.00.txt\) failed
[08:13:21] bd: not a bd - trying as a stream/file instead
[08:13:21] dvd: not a dvd - trying as a stream/file instead
Input #0, tty, from 'D:\Elokuvia\Elokuva_ Pirates of the Caribbean_ Mustan helmen kirous (12) 2019.07.04 21.00.txt':
Duration: 00:00:00.04, bitrate: 35 kb/s
Stream #0:0: Video: ansi, pal8, 640x400, 25 fps, 25 tbr, 25 tbn, 25 tbc
[08:13:21] scan: decoding previews for title 5
hb_save_preview: Failed to open C:/Users/käyttäjä/AppData/Local/Temp/hb.18428/8_5_0 (reason: unknown error 2)
avformat_seek_file failed
[08:13:21] Warning: Could not read data for preview 2, skipped
[08:13:21] scan: 1 previews, 640x400, 25.000 fps, autocrop = 0/0/0/0, aspect 1.60:1, PAR 1:1
[08:13:21] Title is likely interlaced or telecined (0 out of 1 previews). You should do something about that.
[08:13:21] scan: Too few previews (1), trying harder
[08:13:21] libhb: scan thread found 1 valid title(s)
hb_read_preview: Failed to open C:/Users/käyttäjä/AppData/Local/Temp/hb.18428/8_5_1 (reason: unknown error 2)
# Scan Finished for Queue Edit ...
Last error repeated 1 times
[08:27:25] hb_init: starting libhb thread
# Starting Scan ...
[08:27:25] CPU: AMD Ryzen 9 3950X 16-Core Processor
[08:27:25] - logical processor count: 32
[08:27:25] Intel Quick Sync Video support: no
[08:27:25] hb_scan: path=D:\Elokuvia\Elokuva_ Beverly Hills kyttä III (12) 2019.07.03 21.00.ts, title_index=1
[08:27:25] bd: not a bd - trying as a stream/file instead
[08:27:25] dvd: not a dvd - trying as a stream/file instead
[08:27:25] file is MPEG Transport Stream with 188 byte packets offset 0 bytes
[08:27:25] Found the following PIDS
[08:27:25] Video PIDS :
[08:27:25] 0x515 type H.264 (0x1b) (PCR)
[08:27:25] Audio PIDS :
[08:27:25] 0x516 type MPEG1 (0x3)
[08:27:25] 0x517 type MPEG1 (0x3)
[08:27:25] Subtitle PIDS :
[08:27:25] Other PIDS :
[08:27:25] 0x518 type DVB Teletext (0x0)
[08:27:25] stream id 0x516 (type 0x3 substream 0x0) audio 0x516
[08:27:25] stream id 0x517 (type 0x3 substream 0x0) audio 0x517
[08:27:26] scan: decoding previews for title 1
[08:27:26] file is MPEG Transport Stream with 188 byte packets offset 0 bytes
[08:27:26] scan: audio 0x517: mp2, rate=48000Hz, bitrate=128000 Nederlands (MPEG) (2.0 ch) (128 kbps)
[08:27:26] scan: audio 0x516: mp2, rate=48000Hz, bitrate=128000 suomi (MPEG) (2.0 ch) (128 kbps)
hb_save_preview: Failed to open C:/Users/käyttäjä/AppData/Local/Temp/hb.18428/9_1_0 (reason: unknown error 2)
hb_save_preview: Failed to open C:/Users/käyttäjä/AppData/Local/Temp/hb.18428/9_1_1 (reason: unknown error 2)
hb_save_preview: Failed to open C:/Users/käyttäjä/AppData/Local/Temp/hb.18428/9_1_2 (reason: unknown error 2)
hb_save_preview: Failed to open C:/Users/käyttäjä/AppData/Local/Temp/hb.18428/9_1_3 (reason: unknown error 2)
hb_save_preview: Failed to open C:/Users/käyttäjä/AppData/Local/Temp/hb.18428/9_1_4 (reason: unknown error 2)
hb_save_preview: Failed to open C:/Users/käyttäjä/AppData/Local/Temp/hb.18428/9_1_5 (reason: unknown error 2)
hb_save_preview: Failed to open C:/Users/käyttäjä/AppData/Local/Temp/hb.18428/9_1_6 (reason: unknown error 2)
hb_save_preview: Failed to open C:/Users/käyttäjä/AppData/Local/Temp/hb.18428/9_1_7 (reason: unknown error 2)
hb_save_preview: Failed to open C:/Users/käyttäjä/AppData/Local/Temp/hb.18428/9_1_8 (reason: unknown error 2)
hb_save_preview: Failed to open C:/Users/käyttäjä/AppData/Local/Temp/hb.18428/9_1_9 (reason: unknown error 2)
[08:27:27] stream: 17 good frames, 0 errors (0%)
[08:27:27] scan: 10 previews, 1920x1080, 25.000 fps, autocrop = 0/0/0/6, aspect 16:9, PAR 1:1
[08:27:27] scan: supported video decoders: avcodec qsv
[08:27:27] libhb: scan thread found 1 valid title(s)
hb_read_preview: Failed to open C:/Users/käyttäjä/AppData/Local/Temp/hb.18428/9_1_1 (reason: unknown error 2)
[09:19:53] hb_ts_stream_decode - eof
[09:19:53] reader: done. 33 scr changes
[09:22:55] work: average encoding speed for job is 0.987745 fps
[09:22:55] comb detect: heavy 170973 | light 18021 | uncombed 16472 | total 205466
[09:22:55] decomb: deinterlaced 170973 | blended 18021 | unfiltered 16472 | total 205466
[09:22:55] vfr: 205480 frames output, 0 dropped and 14 duped for CFR/PFR
[09:22:55] vfr: lost time: 0 (0 frames)
[09:22:55] vfr: gained time: 0 (0 frames) (0 not accounted for)
[09:22:55] stream: 410960 good frames, 0 errors (0%)
[09:22:55] mp2-decoder done: 342460 frames, 0 decoder errors
[09:22:55] h264-decoder done: 205479 frames, 0 decoder errors
[09:22:55] sync: got 205466 frames, 204926 expected
[09:22:55] sync: framerate min 2.273 fps, max 25.000 fps, avg 24.998 fps
x265 [info]: frame I: 2121, Avg QP:5.72 kb/s: 59630.23
x265 [info]: frame P: 46782, Avg QP:4.82 kb/s: 71850.55
x265 [info]: frame B: 156577, Avg QP:8.37 kb/s: 34668.25
x265 [info]: Weighted P-Frames: Y:1.4% UV:0.9%
x265 [info]: Weighted B-Frames: Y:1.3% UV:0.9%
x265 [info]: consecutive B-frames: 8.7% 6.1% 6.3% 48.3% 10.9% 10.6% 3.9% 4.3% 0.8%
encoded 205480 frames in 208127.50s (0.99 fps), 43391.28 kb/s, Avg QP:7.53
[09:22:55] mux: track 0, 205480 frames, 44581018021 bytes, 43384.05 kbps, fifo 512
[09:22:55] mux: track 1, 385268 frames, 165426255 bytes, 160.98 kbps, fifo 2048
[09:22:55] Finished work at: Tue Sep 22 09:22:55 2020
[09:22:55] libhb: work result = 0
# Encode Completed ...
voisiko ammattilainen avata tietämättömälle mikä meni pieleen.
eikös encode preset ja quality vaikuta laatuun? tarkoitan että olen ymmärtänyt että niillä saadaan videosta varmemmin sellainen kuin se pitäisi olla, ilman että tulee virhepikseleitä, mutta ilmeisesti vissiin ne vaikuttaa kokoonkin.:confused:
miten saan videon kokoa pienennettyä, ilman että sillä on vaikutusta laatuun?
Ensin ripataan MakeMKV-ohjelmalla ja sitten tarvittaessa pienennetään tiedoston kokoa HandBrake-ohjelmalla.
- The most popular Blu-ray decrypter in the market at free of cost.
- MakeMKV not only can rip Blu-ray and DVD, but also can transcode video to MKV (lossless MKV: with multi-audio tracks/chapter markers).
- If you want to retain your videos in MKV format but save space, you can use HandBrake to convert these videos to smaller MKV files.
- HandBrake’s preview feature allows you to perform a test run on a small portion of your source, so you can see what your new video will look like without encoding all of it.
1. Source: Valitaan video joka pakataan.
2. (Tätä ei yleensä tarvita) Some sources may contain more than one video clip, or a collection of titles. Use HandBrake’s title control to select which video clip you want to use.
3. Presets-valikko: Valitaan esiasetuksista videokoodekiksi esim. "H.264 MKV 1080p30" tai "H.265 MKV 1080p30" ja valitaan hiiren oikealla "Set Default".
4. Destination: Määritetään pakatun tiedoston sijaintikansio ja tiedostonimi.
5. Video-välilehti: "Constant Quality" -liukusäätimellä säädetään tiedoston kokoa. Pienempi RF-numero tarkoittaa laadukkaampaa kuvaa, mutta suurempaa tiedoston kokoa.
Recommended settings for x264 and x265 encoders:
RF 18-22 for 480p/576p Standard Definition
RF 19-23 for 720p High Definition
RF 20-24 for 1080p Full High Definition
RF 22-28 for 2160p 4K Ultra High Definition
6. Audio-välilehti: Äänikoodekki on oletuksena "AAC". Valitaan "Auto Passthru" jos halutaan säilyttää alkuperäinen ääni muuttumattomana.
7. Subtitles-välilehti: Valitaan "Add Track" > "Add All Remaining Tracks". Ruksataan pois "Foreign Audio Scan".
8. "When Done" > "Suspend"
9. "Start Encode"
Timo 2
Premium-jäsen
Olisiko näistä ohjeista apua, kun olen tehnyt varmuuskopioita Blu-ray-levyistä.
- The app will say “MakeMKV BETA” at the top — ignore this. It works just fine.
- HandBrake can process most common multimedia files and any DVD or BluRay sources that do not contain any kind of copy protection.
- I recommend using the "H.264 MKV 1080p30" preset for Blu-rays, and the "H.264 MKV 576p25" (PAL format) or "H.264 MKV 480p30" (NTSC format) presets for DVDs.
2. Some sources may contain more than one video clip, or a collection of titles. Use HandBrake’s title control to select which video clip you want to use.
3. Presets-valikko: Valitaan esiasetuksista videokoodekiksi "H.264 MKV 1080p30" tai "H.265 MKV 1080p30" ja valitaan hiiren oikealla "Set Default".
5. Video-välilehti: Siirretään "Constant Quality" -liukusäädin kohtaan "16 RF" tai "18 RF" (oletusasetuksena on 22 RF). Pienempi RF-numero tarkoittaa laadukkaampaa kuvaa, mutta suurempaa tiedoston kokoa.
6. Audio-välilehti: Valitaan äänikoodekiksi oletuksena oleva "AAC" (tai "Auto Passthru" jos halutaan säilyttää alkuperäinen ääni muuttumattomana).
7. Subtitles-välilehti: Valitaan "Add Track" > "Add All Remaining Tracks" > ruksataan pois "Foreign Audio Scan" > asetetaan "Finnish" defaultiksi.
9. "Start Encode"
Kiitos vinkeistä.
En ollut täysin ymmärtänyt tuota rf numeroa ja ajattelin mitä pienempi, sen parempi ja tämän takia se oli aika pieni (5) ja se selittää tuon kasvaneen koon näköjään.
Mutta mietin sitä että milloin kuva on riittävän laadukas, muuttuuko tuon 16 jälkeen oikeastaan mikään muu kuin videon koko? Ja mikä vaikutus on resoluutiolla tuohon rf arvoon? Onko tuo 16 hyvä kaikille resoluutioille?
OsQ
RF lukuna olen käytellyt 16-18, tosin erot on < 20 aika pieniä. Muistaakseni tiedostokoko kasvaa melko exponentiaalisesti laatuun nähden kun toi luku laskee.
Pienempää kuin 16 on turha valita, koska se kasvattaa tiedoston kokoa, mutta kuvanlaadun paranemista ei käytännössä huomaa.
248 206
Osimandius
