Tp-link be65 kokemuksia
Joo, 4 kpl järjestelmä ollut ajossa viime kesästä asti. Olen tykännyt, pystytys esimerkilllisen sujuva, paljon featureita, hyvä suorituskyky. Erikoisempi juttu, että laitteesta on kahta HW- versiota V1 ja V2 liikkeellä, jotka elävät eri aikaa firmware politiikassa.
Reactions: Meq
Google Gemini osaa kertoa tarkemmin tuosta V1 ja V2 eroavaisuudesta:
"Based on the information available, the primary hardware difference between the TP-Link BE65 V1 and V2 lies in their 2.4 GHz band capabilities:
* Deco BE65 V1: The 2.4 GHz band supports Wi-Fi standards 802.11b/g/n/ax (Wi-Fi 6). It does not support the newer 802.11be (Wi-Fi 7) standard on this band.
* Deco BE65 V2: The 2.4 GHz band supports a wider range of Wi-Fi standards, including 802.11b/g/n/ax and 802.11be (Wi-Fi 7).
This means that devices connecting to the 2.4 GHz band of a V2 unit can potentially achieve higher speeds and better efficiency if they also support Wi-Fi 7. V1 units will be limited to Wi-Fi 6 speeds on the 2.4 GHz band.
Other potential differences and similarities:
* Firmware: As of late 2024, the firmware for V2 was one step ahead of V1, with version 1.1.0 offering new features. V1 firmware updates might have followed since then, but initially, V1 lagged slightly in software features. However, more recent information suggests that both V1 and V2 have been updated with similar software features.
* Regional Variations: There might be regional differences in hardware versions, with V1 potentially being more common in the EU and V2 in the US. These regional differences can sometimes lead to slight variations in wireless specifications due to local regulations. For example, there might be a difference in the total theoretical Wi-Fi speed (e.g., BE19000 vs. BE22000) due to these regulations.
* Overall Network Performance: Despite the 2.4 GHz band difference, overall network performance between V1 and V2 is reported to be consistently comparable after firmware updates brought similar features to both versions.
* Other Specifications: Both hardware versions of the Deco BE65 are Tri-Band Wi-Fi 7 systems, typically offering:
* 6 GHz band: Supporting 802.11be (Wi-Fi 7) with high speeds (e.g., up to 5760 Mbps or 5765 Mbps depending on the source).
* 5 GHz band: Supporting 802.11be (Wi-Fi 7) with high speeds (e.g., up to 2880 Mbps or 4320/4324 Mbps depending on the source).
* 2.5 Gbps Ethernet Ports: Usually equipped with 4 x 2.5 Gbps ports that support WAN/LAN auto-sensing.
* USB 3.0 Port: Often includes a USB 3.0 port for features like FTP server, media server, and potentially Apple Time Machine support.
* Mesh Technology: Both versions utilize TP-Link's mesh technology for seamless whole-home coverage.
* Features: They generally support features like Multi-Link Operation (MLO), 320 MHz channels, TP-Link HomeShield, and the ability to connect a large number of devices (around 200).
In summary, the key difference is the 2.4 GHz band's support for Wi-Fi 7 in the V2 hardware, which is absent in V1. While there might have been initial firmware differences, both versions have received updates that bring their feature sets closer. Regional variations could also lead to minor specification differences."
Joo tuli nyt yks tollanen ostettua tarjouksesta. Laitoin dna 5g kotimokkulan jatkeeksi wifi hommiin. Saas nähä miten toimii.
ICT-Pudi
