Time Machinen asetuksia pääsee säätämään, mutta itse Time Machine on käytössä vain ulkoisella levyllä joten vastaus on kaiketi ei.Aukeaako time machine jos USB levy ei ole kiinni?
Toimii ihan hyvin.Entä toimiiko USB-levy kun se on kiinni koneessa ja et ole käynnistänyt time machinea?
Levy on osioitu kahteen osaan. Toinen on ExFat ja back up osio on "Mac OS laajennettu (kirjainkoon erotteleva, kirjaava)"Oletko formatoinut levyn HFS+ järjestelmään?
Jul 31 00:17:43 macistin com.apple.backupd[1665]: Starting automatic backup
Jul 31 00:17:43 macistin kernel[0]: nspace-handler-set-snapshot-time: 1501456665
Jul 31 00:17:43 macistin com.apple.mtmd[218]: Set snapshot time: 2017-07-31 00:17:45 +0100 (current time: 2017-07-31 00:17:43 +0100)
Jul 31 00:17:43 macistin com.apple.backupd[1665]: Network destination already mounted at: /Volumes/Data
Jul 31 00:17:52 macistin com.apple.backupd[1665]: Checking for runtime corruption on /dev/disk2s2
Jul 31 00:17:57 macistin kernel[0]: hfs: mounted Time Machine Backups on device disk3s2
Jul 31 00:17:57 macistin mds[68]: (Volume.Error:880) Root store set to FSOnly with matching create! (loaded:1)
Jul 31 00:17:58 macistin com.apple.backupd[1665]: Disk image /Volumes/Data/macistin.sparsebundle mounted at: /Volumes/Time Machine Backups
Jul 31 00:17:58 macistin com.apple.backupd[1665]: Network destination already mounted at: /Volumes/Data
Jul 31 00:18:42 macistin com.apple.backupd[1665]: Disk image already attached: /Volumes/Data/macistin.sparsebundle, DIHLDiskImageAttach returned: 35 (Resource temporarily unavailable)
Jul 31 00:18:42 macistin diskimages-helper[1694]: *** -[NSMachPort handlePortMessage:]: dropping incoming DO message because the connection is invalid
Jul 31 00:18:44 macistin com.apple.backupd[1665]: Disk image /Volumes/Data/macistin.sparsebundle mounted at: /Volumes/Time Machine Backups
Jul 31 00:18:44 macistin diskimages-helper[1696]: *** -[NSMachPort handlePortMessage:]: dropping incoming DO message because the connection is invalid
Jul 31 00:18:45 macistin com.apple.backupd[1665]: Backing up to /dev/disk3s2: /Volumes/Time Machine Backups/Backups.backupdb
Jul 31 00:18:51 macistin com.apple.backupd[1665]: Will copy (91.8 MB) from OSXroot
Jul 31 00:18:51 macistin com.apple.backupd[1665]: Found 237 files (91.8 MB) needing backup
Jul 31 00:18:51 macistin com.apple.backupd[1665]: 6.23 GB required (including padding), 57.42 GB available
