Ratkaistu Tietokone ei mene lepotilaan
Vaihdoin emolevyn, prosessorin ja muistit tällä viikolla ja nyt tietokone ei mene enää lepotilaan. Ajoin CMD:ssä komennon -powercfg /energy joka palautti näin:
Power Policy: Power Plan Personality is High Performance (Plugged In)
The current power plan personality is High Performance when the system is plugged in.
Power Policy: Display timeout disabled (Plugged In)
The display is not configured to turn off after a period of inactivity.
Power Policy:Sleep timeout is disabled (Plugged In)
The computer is not configured to automatically sleep after a period of inactivity.
Power Policy: Disk idle is disabled (Plugged In)
The disk is not configured to turn off after a period of disk inactivity.
Power Policy:Minimum processor performance state is 100% (Plugged In)
The processor is not configured to automatically reduce power consumption based on activity.
Power Policy: PCI Express ASPM is disabled (Plugged In)
The current power policy for PCI Express Active State Power Management (ASPM) is configured to Off.
USB Suspend:USB Device not Entering Selective Suspend
This device did not enter the USB Selective Suspend state. Processor power management may be prevented when this USB device is not in the Selective Suspend state. Note that this issue will not prevent the system from sleeping.
Device Name USB Composite Device
Host Controller ID PCI\VEN_8086&DEV_A2AF
Host Controller Location PCI bus 0, device 20, function 0
Device ID USB\VID_045E&PID_0779
Port Path 12
Device ID USB\VID_046D&PID_C24D
Port Path 8
Device ID USB\VID_046D&PID_C332
Port Path 7
Platform Power Management Capabilities:ACPI _PSS Object Failed Validation
There is a problem with the definition of the ACPI _PSS object on this computer. Installing the latest system firmware (BIOS) may resolve this issue.
Group 0
Index 0
Group 0
Index 1
Group 0
Index 2
Group 0
Index 3
Group 0
Index 4
Group 0
Index 5
Group 0
Index 6
Group 0
Index 7
Group 0
Index 8
Group 0
Index 9
Group 0
Index 10
Group 0
Index 11
Platform Power Management Capabilities: PCI Express Active-State Power Management (ASPM) Disabled
PCI Express Active-State Power Management (ASPM) has been disabled due to a known incompatibility with the hardware in this computer.
Kun painan Sleep niin ruutu pimenee mutta melkein heti herää uudestaan lukitusruudulle.
Uusi rauta:
Intel i7-8700K
MSI Z370 Gaming Plus (uusin BIOS, päivitin sillä MSI:n ohjelmalla Windowsista, Live Update 6:lla siis)
2x8GB Kingston HyperX Fury 2666Mhz DDR4
powercfg -lastwake
Komentokehotteessa ajat ton komennon niin näyttää syyn miksi herännyt sleepistä. win 7 ainakin toimii.
Hiiri on mulla ollut usein syynä.
Tietokone menee nyt lepotilaan. En tiedä mikä oli syynä, ehkä BIOS jotenkin... Nimittäin flashasin BIOSin uudestaan, nyt tikulta (aiemmin siis Windowsista) ja sen jälkeen kone meni lepotilaan. Samalla hävisi tuolta energy-raportista nuo kohdat
"Platform Power Management Capabilities:ACPI _PSS Object Failed Validation
There is a problem with the definition of the ACPI _PSS object on this computer. Installing the latest system firmware (BIOS) may resolve this issue."
Eli ehkä BIOS oli jotenkin huonosti flashattu kun Windowsista sen tein, en tiedä. Tai sitten mulla oli joku asetus siellä joka esti lepotilan... No, joka tapauksessa nyt toimii :tup:
E.T
BIOSia ei koskaan pidä päivittää Windowsista käsin, varsinkaan kun siihen on emolevyissä niin helpot työkalut.
Mitä enemmän niitä softakerroksia on päivityksen ajon ja raudan välissä, sen enemmän siinä välissä on bugeja ja mahdollisuuksia mennä vikaan.
Itellä oli joskus asrockin laudan ja asuksen pcie -äänikortin (xonar jotain) vastaava ongelma, mikä ei rauennut kun nykäsemällä äänikortti pois.
Ihan vaan jollekin muulle tiedoksi jos sattuu tänne säikeeseen oma lehmä ojassa.
248 222
Osimandius
