terassin huoltaminen
Hey! Sorry for the english, hoping I will get some help here. So, as the spring is here and the summer is coming, I was thinking of doing some maintenance of the terassi. The house was purchased last autumn, so I haven't done anything with so far. I have done some photos of it, so you can take a look of the current condition of it.
So I know that there are this preservation oils and everything, I even have a bucket. But what I was considering, is do you think this also requires some painting? If so, what's the process of it? Does it require some sandpapering, then some base paint, then some actual paint, and then the oil? Or is the oil itself enough?
I am a noob in all this, so happy to take any help.
Thank you in advance, and sorry for writing in english. My finnish is still under work. :)
If you have high pressure washer then this is a good add-on for deck washing
Depends on the desired outcome. The decking doesn't look too filthy, so you could achieve great results by simply washing it with a suitable washing product and a brush. it looks a bit in picture 3, that there is some green (algae?) on the balcony that can probably be removed with the washing product and brushing. Then after a couple of days of drying, apply wood oil with the color of your choice. This combination will already make a big difference in appearance, ease the maintenance of the decking and lengthen its lifetime.
Agree to this. Based on the pictures there's absolutely no need for any grinding/sand papering (except maybe the stairs on pict 4). Just wash and oil.
Some products to recommend:
Biocomp Terassipesu for cleaning: AB BioComb
Tikkurila Valtti Kaluste- ja Terassiöljy for oiling: Valtti Kaluste- ja Terassiöljy | Tikkurila
You can find these in any K-Rauta, Bauhaus or Prisma.
I agree with previous replies, don’t paint, wash and oil it.
To make your life easier on multiple tasks, buy a pressure washer and get one with a deck washer attachment. It makes washing the deck a breeze, and there are a lot of other use cases for a pressure washer around the house.
The steps look worse than the rest of the deck. Depending on how they look after the wash, they might require some sanding before the oil...
It's good to have around. Unless you have a very eager DIY enthusiast father-in-law. In that case, avoid having a high pressure washer on your property. Ignoring this rule eventually cost this Espoo couple some 300k€.
Ap varmaan jo saanut asiansa hoidettua ja voidaan varmaan suomeksi vaihtaa.
Meillä aika iso terassi, ajattelin tuolla biocompilla pestä. Voiko levittää painepesuriin liitettävällä vaahdottimella? Ja sitten vetäisi tuolla kärcherin päällä joka linkatttu ylhäällä? Kaiteet myös vetäisin vaahdottimella, mutta millä sitten hinkkaisi puhtaaksi? Naapurit vetäs ihan tollasella terassiharjalla öljyt pintaan, kun olis menny selkä ja terveys muuten. Kaiteet jne sitten ihan siveltimellä. Varmaan tähänkin on joku oma työkalunsa?
Kannattaako nuo halvimmat öljyt kietää kaukaa? Suoraan vaan tikkurilan valttia?
Juuriharjalla oon itse jotain ahtaampia välejä harjaillut, tosin en kovin suurella tarkkuudella. Aineen oon levittänyt puutarharuiskulla.
Terassiöljyn levitykseen käyttänyt Sinin terassiöljyharjaa, saa Sinin jatkovarteen kiinni, löytyy varmaan muitakin merkkejä. Sileään lautaan toimii varmaan sellanen lastamallikin.
Onko kukaan mitään ruiskua käyttänyt öljyämiseen.
Itsellä on 160m2 terassi pinta alaa ja voitte arvata mikä savotta siinä on. Haasteellisemmaksi tekee se että lauta on profiloitua ja terassi sienellä öljyäminen mahdottomuss koska profiloidusta urasta lähtee tikkuja ja sieni hetken päästä kuin piikkisika.
Sain viime vuonna vedettyä noin 50% sienellä, loput isolla siveltimellä kepin päässä. Helppous ruiskussa houkuttaa.
Olisiko kellään suositella jotain?
Tätä meni viime vuonna kaksi kannua: Woodex Wood Oil väritön puuöljy 9l - K-Rauta
Tuota laitan tänäkin vuonna.
Oma terassi oli aika huono pinnaltaan niin päädyin hiomaan sen ensin. Painepesurilla sai hyvin pinnan putsattua ja öljyäminen hoitui siveltimellä n. 20m2/h vauhtia.
Sorry if my English is a bit unclear, it's not my strenght, but I'll give it a try anyway. I just did a terrace renovation last summer for our family home. Based on my experience, I can talk about the best way to prepare and make wood durable. We also got new furniture and a gazebo in the same package, got them pretty cheap from preeco.fi . However, it's important to first sand the wood thoroughly and clean the surface from dirt before painting when it's clean. If you're not painting, then using a good wood oil for oiling is probably the best option, you can get quality ones from Tikkurila, they last a long time.
Mikä terassiöljy (kirkas) terassin huoltamiseen? Onko väliä minkä hommaa, onko laaduissa isoa eroa? Millä paras levittää? Terassia on kohtuureilusti kuitenkin.. Tokmannilta vaan joku vaiko jotain "premiumia jostain K-raudasta?"
Jonkun mielestä öljyn laadusta ja "öljyisyydestä" kertoo tuotteen kuiva-ainepitoisuus. Olen itse käyttänyt pienen parvekkeen akaasia laattojen öljyämiseen tung öljyä jossa on 45% kuiva-aine pitoisuus. Tämä on hyvää tavaraa, mutta ei terasseihin hinnan ja homeenestoaineen puutteen vuoksi. Lisäksi tuolla jää puun pintaan selvä kalvo jos kaikki öljy ei imeydy puuhun. Terassiöljyt on ohennettu vedellä tai liuottimilla, jolloin ne ovat helpompia sivellä pinnoille ja imeytymätöntä öljyä jää pinnalle vähemmän muodostamaan kalvoja. Lisäksi terassiöljyihin on lisätty homeenestoainetta. Omasta mielestäni liuotinohenteiset terassiöljyt ovat helpompia levittää ja ne imeytyvät puuhun paremmin ja siksi käytän vain niitä. Esim. tämä on hyvä. Olen joskus öljynnyt terassia vesiohenteisella öljyllä ja tuntui että tuota sai suorastaan hangata että imeytyi. Terassi oli kyllä vanha ja siinä oli varmaan vuosien lika- ja öljykerrostumia mikä vaikeutti vesiliuotteisen öljyn imeytymistä. Uudelle puulle vesiohenteinen voisi toimia paremmin. Levitykseen esim. iso sivellin pitkällä puuvarrella, ettei joudu kyykistelemään.
Mulla on tossa vähän vajaa 100 neliötä terassia nykyään pihalla, joten öljyn hinnalla alkaa olemaan väliä. Yhtenä kesänä vedin jotain "merkkiöljyä" siihen kun sai tarjouksesta, sen jälkeen käyttänyt lähinnä näitä Tokmanni/Rusta tason peruslitkuja enkä kyllä huomaa eroa muussa kuin värisävyssä joka öljyyn on sotkettu; osa on vaaleampia ja osa tummempia, meillä siis käsitelty ruskealla öljyllä.
Käytän siis vastedeskin halpiksia jotka maksavat puolet vähemmän kuin "merkkituote".
Pitäisi nyt kesällä laittaa uudet maalit terassin rima-aitaan & kaiteisiin - mutta milläpä on järkevin ottaa vanha maali pois rimoilta? Jokaisen riman irrottaminen epäkeskon rakkautta varten kuulostaa aika hapokkaalta hommalta, joten toimisiko esim. soodapuhallus hommaan?
jnur
