Temperature Q/A pc.
I just bought a new pc. First time experience with AMD.
Processor: AMD Ryzen 5 3600
Motherboard: Asus Rog B450-F
GPU: Gainward GeForce RTX 2070 twinx
CPU Cooler: SilverStone PF240-ARGB, 240mm water cooling system
Case: MSI MPG GUNGNIR 100.
1. When I run google chrome or any other application. My Cpu temp. jumps between 51-61C. When I go to bios its usually around 50C. Is that normal for AMD CPUs?
2. When I play any graphics-heavy games, My GPU just stay constant 79C. Is that ok ? or I have some issues in my setup.
The GPU temperatures are normal. The CPU temps are also normal, if they are idle temps after prolonged use. I run a Noctua NH-D15 with the same CPU you have, and I'm at 50 celsius at the moment. Have you run a CPU stress test?
puririri
