SiliconLottery sulkee kauppansa
Kaotik
Banhammer
Ylläpidon jäsen
Esitestattuja eli ns. pre-binned prosessoreita myyvä SiliconLottery sulkee verkkokauppansa.
Tiedotteen mukaan syitä sulkemiseen on useita, päälimmäisenä heikentyvä ylikellotuspotentiaali prosessoreissa, paremmat Boost-algoritmit ja valmistajien tiukemmat esibinnaukset huippumalleihin. Lisäksi prosessoreiden saatavuus on ollut sivuston näkökulmasta heikkoa jopa jo ennen koronapandemiaa.
Voit lukea koko tiedotteen alta.
STORE CLOSING
Our online store will be closing on October 31, 2021. Any orders placed for our delidding service will need to be delivered to us by November 30, 2021 for completion. For warranty or other assistance after we close the store, contact us at the email listed on your packing slip.
We have had a fantastic time these past seven years at Silicon Lottery. This business has grown and made an impact on so many people, more than I ever imagined was possible. I personally appreciate all of you that I’ve been able to talk with over these years, from troubleshooting to general questions to speculation. It’s been so easy to connect with so many of you through this hobby we share.
We’re shutting down not for just one reason, but for a combination of many. As you may be aware, overclocking headroom has been dwindling these past several years with manufacturers offering higher frequencies at stock, better boosting algorithms, and tighter bins between models which reduces overclock frequency variation (the 11900K is essentially a binned 11700K, so with the 11900K we’re binning what has already been fairly heavily binned). This type of product segmentation is nothing new, but having such minor differences between two models is a more recent shift. Intel has also switched from a polymer TIM back to a solder TIM starting with their 9th generation CPUs, which has reduced the thermal benefits achieved from delidding. In addition, supply issues have taken a major toll on us, even before the pandemic started. Our orders with distributors for the last few releases have been nightmares of delays upon delays.
With all of this in mind, sales have fallen below the point where it makes sense for us to keep the store open. We know many of you are eagerly wanting Alder Lake CPUs, and we’re sorry that we won’t be able to fulfill your needs this time. We have seen your emails rolling in these past couple of weeks, and we’re sorry for not getting back to you guys earlier as we’ve been busy juggling this decision.
While we will be closed for the foreseeable future, it’s not necessarily goodbye forever. If things change in the market, in particular if overclocking headroom and variation increases for whatever reason, it’s possible we will get things rolling again.
We wish all of you the best, and to keep having fun tweaking hardware!
escalibur
"Random Tech Channel" @ YouTube
Kellotus on muutenkin menettänyt merkityksensä vuosien saatossa. Monesti siitä on aivan liikaa vaivaa ja epävakausriskejä suhteessa haalittuun hyötyyn eri tilanteissa.
Kaukana ovat ne ajat, kun prosessorin sai sokeasti kellottaa useita kymmeniä prosentteja suhteessa vakionopeuteen. Tämä ei välttämättä ole huono asia, sillä nykyisin tämä kellotus on varmasti jossain määrin hoidettu jo tehtaalla.
Kellotus on muutenkin menettänyt merkityksensä vuosien saatossa. Monesti siitä on aivan liikaa vaivaa ja epävakausriksejä suhteessa haalittuun hyötyyn eri tilanteissa.
Kaukana ovat ne ajat kun prosessorin sai sokeasti kellottaa useita kymmeniä prosentteja suhteessa vakionopeuteen. Tämä ei välttämättä ole huono asia, sillä nykyisin tämä kellotus on varmasti jossain määrin hoidettu jo tehtaalla.
Jep prossut alkavat olla jo vakiona niin pitkälle binnattuja, että hyödyt ovat aika marginaalisia verrattuna hintaan mitä pitää maksaa extraa tuollaisesta palvelusta. Lisäksi molemmat Intel ja AMD ovat siirtyneet cpu kivien juottamiseen kiinni lämmönlevittäjään jo tehdas malleina, joten lämmönlevittäjien irrottelusta ja omien lämmönlevitys systeemmien rakentelusta siihen päälle ei enää saa samaa hyötyä kuin ennen. Hyödyt ovat aika marginaalisia siihen nähden, että takuu menee.
Esim. itse olen omassa AMD prossussani ylikellottanut vain muistiohjaimen, koska siitä saa selkeää etua, mutta CPU kiveä en ole ylikellottanut, koska liikaa vakausongelmia jos yrittää saada molemmat muistiohjaimen ja CPU kellotettua samaan aikaan. En ole niin himokellottaja, että haluaisin etsiä pitkään hyviä asetuksia minulle riittää tämä.
BlackWolf
Suomen Michael Jackson
BANNED
NOSTO
Olen hieman eri mieltä kanssasi. Toisin kuin sanot, niin kellotus ei todellakaan ole menettänyt merkitystään, vaan kellotuksesta tuli niin merkittävä osa koko tietokoneita, että valmistajat alkoivat kellottamaan prosessorinsa/näytönohjaimensa jo valmiiksi. Eli ylikellotus löi täysin läpi itsensä marginaalien touhusta niin ns. main streamiin, että valmistajat alkoivat tekemään sen boosteissaan mitä ennen teki marginaali porukat kotonaan. Sehän on itseasiassa suurin kunnianosoitus kaikkia niitä kohtaan jotka ovat olleet osaltaan niitä koneita kellottamassa ja asioista internetissä puhumassa, sekä tietoa jakamassa.
Ei ihme että ei kiinnosta kellotella. Lukekaapa vaikka noita ohjeita ZEN 3 prossujen kellotteluun että saa sen 50-200MHZ hyödyn eli jotain 2-3% tai vastaavasti monisäikeisessä työssä 5-15%. Aivan onneton hyöty siihen nähden mikä työ ja testaus hommaan kuuluu. Puhumattakaan kuinka systeemin vakaus on vakio kun tahnat jähmettyy ja menettää lämmönjohtokykyä tai talven kellotukset ei oikein skulaakkaan kesän lämmöillä.
Ei kiiton meikäläiselle enää ja oikeastaa ihan hyvä näin asiakkaan näkökulmasta että binnattu tehtaalta tappiin asti niin saa parasta mitä rahalla saa heti paketista ilman lisäsäätöä. Harrastelijoita saleen harmittaa että ei tule etua enää niin paljoo, mut tilanne on nyt tämä.
Minä ihan mielelläni ostin 6-ytimisen 3700X:n puoleen hintaan, eli 3600 kellotettuna 4.4GHz:iin juurikaan jännitteitä virittämättä. 5600 on jäänyt ostamatta kun sellaista ei ole tarjolla, on vain se malli missä kellot (ja hinta) on jo valmiiksi kiristetty yläkanttiin.
Että on se kellotus ihan kannattavaa silloin kun valmistaja tarjoaa siihen mahdollisuuden eikä silikonilotossa ihan puhdas luu jää käteen.
Tämän takia kyseinen putiikki olikin olemassa, että prossut testataan ennakkoon vakaiksi ja vaiva maksetaan etukäteen rahana. Useat meistä ostaa mitä erilaisempia asioita palveluna, sen sijaan että itse tekee. Syy silicon lotteryn sulkemiseen olikin siis osaltaan siinä, että kyseistä ylikellotuspotentiaalia on alettu hyödyntämään tehokkaasti jo tehtaalla.
TheMeII
Übertaktungspotenzial
S Y N T H W A V E
Boostit voi myös ajatella niin että ne sirut on tehty niin ylikellotetuiksi että niillä on useita matalampia tasoja joilla ne joutuu ajamaan kun eivät enää toimi oikeilla taajuuksillaan.
Boostikellot kuulostaa hienoilta kun taas jos markkinoitais että ne ajaa isommalla kuormalla oikealla kellotaajuudella max 200ms jonka jälkeen tiputaan energiansäästötasoille niin kaikki ois heti barrikadeilla
247 360
mattila.
