Paras virustorjunta/softapalomuuri?
Panda 18.4.0 muutokset:
Panda Security Forum - View topic - 30% load CPU and endless logining
New features / improvements included in Panda Protection 18.4.0:
New completely redesigned user interface.
New VPN protection. (pakotettu asennus!)
New Firewall technology based on NBL.
Alert support in Tablet mode.
Changes in driver installation technology in W10 (PNPUtil).
Integration in WSC-WDSC for W10 RS3.
Ability to remove licenses from a PC.
Internal improvements to reduce writing in the configuration stores (The number of writing operations in the license dat has been reduced).
Compatibility with Cloud Files in W10 RS3.
Bug fixes
[BUGFIX] If you insert an exclusion from a folder that is inside another folder without more subfolders, the product assigns the exclusion to the upper folder. If there is more than one subfolder, the exclusion is assigned correctly.
[BUGFIX] when an element that has been sent to quarantine is restored, the exclusion is done by malware ID which causes that all the elements that are detected under that same malware ID, stop being detected.
[BUGFIX] It does not work to kill a reliable parent process which in turn is loading a process detected by Deteven's context. Loading (eg VBS) is avoided, but killing the parent (eg Word from which a vulnerability is exploited) does not work.
[BUGFIX] PSANModROL: Remove current date from licenses not checked in offline mode to prevent an incorrect date from being stored.
[BUGFIX] [PSNCDSVF] Bug - Syncronization of CStore. (Correction of a service drop)
[BUGFIX] [PSANModScheduler] Wrong type reading cfg item from store.
[BUGFIX] Fixed 100% percent cleanup when doing the task.
[BUGFIX SF # 04587217] [psinprot] Bug. BSOD because of bad synchronization.
[MS SYSDEV BUGID 11453149]: PSUAMain.exe crashes when application is closed from taskmanager
[MS SYSDEV BUGID 12624376]: Application crashes on clicking on reboot later while uninstalling Panda Protection
[BUGFIX] Removed cyren phishing / malware categories to reduce false positives.
Kaspersky tuntuu voittavan kaikki testit, saaden hyvät pisteet resurssien käytössä. Olen pari vuotta käyttänyt Kaspersky Total Securitya ja kahdella koneella on sen takia ruvennut äänet pätkimään. Ensin luulin että korkea DPC latenssin syynä oli viallinen verkkokortti, mutta selvisi että vika olikin palomuurin nettimonitorointissa. Äänessä oli latenssia parhaimmillaan satoja millisekuntteja. Eikä luulisi olevan koneen tehoistakaan kiinni, kun toisessa päässä tehokkaaman pään i7 ja toisessa 16-core Xeon.
En ole mitään muuta yhdistävää tekijää ainakaan näille ongelmille keksinyt, ja molemmilla koneilla Kasperskyn poistaminen poisti ongelman kokonaan.
Siirryin Windows Defenderin käyttäjäksi, kun ei oikein lämmitä mieltä SYSTEM-oikeuksilla ajettava raskas ohjelmapaketti, jotka tunkee väkisin jotain omia root-certtejään ja skannailee liikennettä...
Nerkoon
Se ainoa oikea
Platinum-jäsen
Kasperskyllä oli ainakin aiemmin sitä, että yksi sen buildi saattoi toimia täydellisesti ja toinen vetää koko koneen jojoon vaikka versionumerossa ei olisi muuttunut juuri mikään. En ole tavannut muilla antiviruksilla vastaavaa.
Windows 10 nopea kehitystahti vaikeuttaa ohjelmistokehittäjien työtä, ja tämä on osittain microsoftin tarkoituskin. Kasperskyn etu muihin nähden on omien kokemusten perusteella käyttöliittymän
selkeys, asetusten runsaus ja hyvä tuki. Jos jokin laajalle levinnyt bugi huomataan, sen korjaamisessa ei yleensä kauan mene.
Niin mitä?
Microsoftin tarkoitus osittain vaikeuttaa ohjelmistokehittäjien työtä?
Miksei Windows 10 nopea kehitystahti tuota muille virustorjunta ohjelmille lähellekkää nsamassa mittakaavassa ongelmia Karspersky:lle?
Niin mitä?
Jos useampi ohjelmistonkehittäjä siirtyy pois win32- rajapinnasta, ja nopeasti, niin sitä parempi microsoftille. Itsellä ei ole ollut mitään vakavampia ongelmia Kasperskyn kanssa
win 7- ajoilta asti, mutta muiden kanssa on ollut säätämistä, esim. avast, avg, McAfee...
https://doublepulsar.com/important-...-fixes-antivirus-vendors-and-you-a852ba0292ec
Lyhyesti sanottuna, jos mistään syystä käyttämäsi AV-ohjelmisto ei aseta noita oikeita rekisteri arvoja kohdilleen, niin Windows ei enää asenna mitään tulevia päivityksiä, muttei myöskään varoita tästä vaan kiltisti sanoo ettei ole päivityksiä ja jatkaa normaalisti toimintaa. Suurin osa peruskäyttäjistä eivät seuraa, että päivittääkö se windows siellä taustalla oikeasti vai ei, kun mitään ilmoituksia ei ruutuun tule, vaan luottaa että asentuvat automaattisesti kuten ennenkin.
Black Friday
Taisin ensimmäistä kertaa eläissäni maksaa virusturvasta .. No 36kk 10:lle eri laitteelle alle 54 eur. Palomuuri myös tuossa premium versiossa.
Saa kaikki koneet ja kännyt myös nuorisolta samaan pakettiin. Sen verran testailin ennen ostoa ettei
mikään raskas softa ole. Vuosi sitten tuo BullGuard voitti kuluttaja lehden testin..
Mikäköhän tällä hetkellä ois hyvä ilmainen virustorjunta ohjelma? Maksullista katon sitten myöhemmin. Uusi kone joka tarvii torjuntaohjelmaa, joten aviraa olen miettinyt, sekä Bitdefenderiä, mutta jotenkin Bitdefenderistä luin että olis hankala poistaa koneelta...oon kääntäny nettii ympäri asian suhteen, kauhea valinnanvaikeus.
Avast minimisuojauksella? Avira asentaa ja tekee muutoksia mm selaimen hakukoneisiin yms. Ei kannata asentaa.
Bitdefender sai mulla tässä uudessa asuksen kannettavassa niitä kuuluisia sinisiä ruutuja aikaan.. En jaksanu selvittää
miksi..
miksi..
Läppärissä Avast, ei oo mitään herjauksia yms. tehnyt. Joten ehkäpä ottaisin sen tähän uuteen (tarjoaa tosin 19e maksullista ohjelmaa, aika halvalla lähtis...). Kovinkaan hämärillä sivuilla ei tuu käytyä koskaan. Myös panda ohjelma kävi mielessä. Oon nettiikin jo kääntäny ympäri asian suhteen, kerralla jos sais perus hyvän.
Meillä bitdefender total security family lisenssi ja kaikissa laitteissa. Ei ongelmia. Netistä kun kaivaa koodin niin saa edullisesti.
Itse en Windows -koneessani ole käyttänyt kolmannen osapuolen tietoturvatuotteita ainakaan viimeiseen 10 vuoteen ja hyvin on pärjätty. En koskaan aja konetta päivittäisessä käytössä administrator -oikeuksilla ja se käytännössä antaa paremman suojan, kuin mikään markkinoilla oleva AV -tuote.
:tup:
Suomalaisesta it-kouluttajasta tuli maailmaa matkavaa Windows-guru – haluaa pääkäyttäjäoikeudet kuriin
(Kopioitu uutisesta): ”Tietoturvallista työasemaa ei voi rakentaa, jos käyttäjällä on pääkäyttäjäoikeudet. Tilanne on parantunut hitaasti, mutta edelleen esimerkiksi huimaavat 94 prosenttia kaikista Microsoftin tuotteisiin liittyvistä kriittisistä tietoturva-aukoista estettäisiin, jos käyttäjällä ei ole pääkäyttäjäoikeuksia”, Laiho sanoo.
Windows 10:ssä on valmiina erinomainen virustorjunta.
A worthy upgrade: Next-gen security on Windows 10 proves resilient against ransomware outbreaks in 2017
(Kopioitu uutisesta): ”Perinteinen niin sanottuihin sormenjälkitunnisteisiin perustuva antivirus on kuollut. Joka päivä löydetään keskimäärin 300 000 uutta haittaohjelmanäytettä. Reaktiivinen suojaus ei voi pysyä siinä tahdissa mukana. Sen sijaan koneisiin voitaisiin tehdä sallittujen ohjelmistojen whitelist.”
Eikös tämä Windows 10:n SmartScreen-suodatin ole käytännössä sama asia kuin em. whitelist?
"SmartScreen on Internet Explorerista Windows-järjestelmään siirretty tekniikka, jonka tarkoituksena on suojata järjestelmää haittaohjelmilta. Se tarkistaa kaikki koneella ajettavat ohjelmat ja vertaa niitä Microsoftin tietokantaan, joka sisältää tietoja mahdollisesti haitallisista sovelluksista."
edit: Lisätty kuva
*Huoh*, taas kerran tätä FUDia, olen jo tästä aiemminkin kirjoittanut, AV:t ovat jo vuosikausia tehneet muutakin kuin tunnisteisiin perustuvaa torjuntaa samaan aikaan. Sitä paitsi ei tuo tunnisteisiin perustuva torjunta ole mitään kuollut, ihan höpöhöpöä. Tunnisteita päivitetään käyttäjien koneisiin tarpeen tullen monta kertaa päivässä. Jos joku uusi pöpö ilmestyy, niin ei se yleensä leviä heti "kaikkiin koneisiin" ennen kuin AV-valmistajat saavat tunnisteet ulos.. ja AV:ssa on muutakin torjuntaa, esim. heurestiikkaa, käyttäytymisanalytiikkaa, jne.
RageDaddy
Team R&T
Kasperky free oli taas muutaman päivän ja selailu venyy ja paukkuu. F-Securen Safe sama homma. Varsinkin io-techin sivujen avautuminen kestää monta sekuntia kauemmin mitä ilman kumpaakaan. Comodo Cloudin uusin beta testauksessa ja ei ainakaan parin tunnin käytön jälkeen hidasta nettiä pätkääkään. Raudasta ei ole kiinni, E5 1650 6/12 prossu ja 32GB muistia sekä intelin 82579LM ja 100M liittymä.
Malwarebytesin maksulliseen versioon kuuluvassa reaaliaikaisessa suojauksessa on massiivisia bugeja, jotka estävät ohjelman ja koneen käytön tällä hetkellä. Muistivuoto täyttää muistin vauhdilla 10-20 MB/s ja kaikki Googleen liittyvät verkko-osoitteet on blokattu. Tällä hetkellä ainoa keino pitää kone toiminnassa on poistaa Malwarebytes käytöstä.
Tuo suht edullisesti hommattu bullguard on toiminut hyvin eikä mitään valittamista ole.. Netscannerin otin pois päältä useimmin käytettävästä koneesta. Eli tuohan ilmoittaa omaan verkkoon kytkeytyvät koneet ja mitä muuta tehneekään..
japau
BANNATTU
BANNED
Malwarebytes 3 premium ja Windows Defender toimii ihan hyvin kimpassa. MB3 realtime protectionit löytää sellasia mihin Windows Defender ei reagoi.
Uusin versio 1.0.3084 asennettuna.
Pitkän tovin käyttänyt jo Bitdefender free editionia, mutta nykyään tämä blokkaa jostain syystä ubiquiti edgerouter x hallintasivun (192.168.1.1) eikä exclusion listalle lisääminen auta. Onko jollain jotain fiksiä tähän vai pitääkö alkaa katselemaan vaihtoehtoja?
Bitdefender Free:ssähän taitaa olla oletuksena ja pakotettuna liikenteen skannaus, eli periaatteessa tekee man-in-the-middle:ä (josta syystä en tuota AV:ta nopean testauksen jälkeen enää edes harkinnut käyttöön), josko tuo aiheuttaisi ongelmasi? Tosin jos aiemmin on toiminut niin sitten en tiedä.
Kyllä se on tämä Bitdefender free joka kyseisen ongelman aiheuttaa, koska heti kun laittaa protection shieldin (eli koko AV:n) stopped tilaan, toimii hallintasivu loistavasti. AV takas käyntiin ja hallintasivu lakkaa toimimasta.
Aikoinaan Bitdefenderiin päädyin juuri sen takia, koska päivittyy hissukseen taustalla, eikä käytännössä juurikaan lauo käyttäjälle popuppeja. Toki miinuksena on tuo vähäinen konfattavuus.
Eikö tuo liikenteen skannaus ole enimmäkseen hyvä asia? Vaikka joidenkin a/v- ohjelmien toteutus saattaa ilmeisesti avata uusia haavoittuvuuksia niin kai turvallisempaa on
pitää kaikki verkon skannaukset päällä?
Olisin voinut olla vähän eksaktimpi, tarkoitin tietenkin, että salatun verkkoliikenteen skannaus MITM-periaattella AV:iden osalta on iso no no minulle. Ainahan kerroksittainen puolustus on parempi, mutta itse olen kauan kauan sitten tullut siihen tulokseen, että itselle riittää pelkkä "file system"-suoja AV:sta, selaimella on omat säädöt ja puolustusmekaniikat otettu käyttöön vähentämään vihulaisten pääsemistä koneelle. Paras suoja on versioiva varmuuskopiointi.
RageDaddy
Team R&T
No vittu sillä lailla. Tuli tuo uusin windowsin päivitys ja hupsista keikkaa. Comodo lens vittuhun, tilalle taas kerran F-Securen Safe mihin mulla 5 vuoden lisenssiä. Noh ans olla, meni päivä ja toinen. Netti tuhannen jumissa, firefox jökittää niin että täytyy riipaista virrat kokonaan pois, chrome jökitti samoin mutta sen sai sentään tapettua tehtävien hallinnan kautta. Vaihtoehtoja tasan 1, elikkäs windows defender ja jo loppu jökittämiset.
Ei oo helppoo, toki vielä tämän illan tämä Dellin T3600 työasema käytössä missä dellin omia virityksiä uefissa/biosissa eikä luonnollisesti sitä enää päivitetä, joten suurin syy näihin löytynee sieltä. Oispa edes yksi AV, mikä EI skannaa liikennettä ja touhuaisi pelkästään pilvessä tai vaikka kännissä mutta toimisi 100%:sesti! Onhan noita joitain, mutta toimivia ei oikein ollenkaan. Ei ilmaisia eikä maksullisia. Windows ja intelihän nämä viimeaikoina on saanut sekaisin, mutta eiköhän joku vielä jostain löydy...
RageDaddy
Team R&T
Kaikissa AV ohjelmissa on hyvät ja huonot puolet.
Älä helvetissä :tup:
Mutta joo, en oikein enää edes muista koska nämä alkoivat lähes kaikki mulkkaamaan verkkoliikennettä ja se on mulle se vittumaisin osa av-paskeita. Talossa 6 ihmistä ja kaikkiaan netissä samaan aikaan pörrääviä vehkeitä kirkkaasti yli kymmenen (osa tosin mobiilin kautta) niin vaikka kaikille on säädetty reitittimestä omat säätönsä niin ei paljoa tarvitse jonkun av softan kikkailla niin oma langan perässä ainoana oleva kone alkaa jökkimään ja vituttaahan se sellanen!
Nyt on delli myyty ja palasteltu, uutta myllyä isketään viikolla kasaan niin siihen laitan pelkän zemanan ja nykäisen defenderin pois päältä. Sillä mennään sitte täältä ikuisuuteen...
F-secure safen tilaus loppuu kolmen viikon päästä. Onko näkynyt hyviä tarjouksia ko. tuotteelle? Jos ei niin mitä suositellaan tilalle? Windowsin omaa kenties?
Pertti Kosunen
Basic Input/Output System
Windowsin omallakin pärjää varsinkin, jos käyttää selaimessa lisäsuojia (mainos- ja skripti jne. blokkerit).
Edit: Bitdefender suositus pois, koska ongelmia.
rupes justiin Bitdefender heittään erroria, vikaraportin lähetystä ja ilmoittaa, että services not responding. Sitten on se kuvake vaan harmaana. Monta kertaa koittanu käynnistää sekä koneen että ohjelman uudelleen, eikä mitään? Aamupäivällä vielä pelas ilman herjoja.
No jopas, ei ole ennen tullu vastaan ja pari vuotta ollu nyt käytössä. Hyvö kumminkin tietää, ettei omalla koneella mitään häikkää olekaan.
Kävin kaverin konetta katsomassa viikko sitten kun valitti että koneella tapahtuu vaikka mitä outoa ja niinhän siellä tosiaan tapahtuikin. Hänelle oli koneelleen tullut Pup.Optional.Tweatkit niminen paske jota Bitdefender Total Security 2018 ei löytänyt. Poistin tuon virustorjunnan väliaikaisesti ja ja sitten windows 10 oma turva päälle joka tuon löysi heti ja kone toimi muutenkin jo ennen sitä paljon nopeammin WIN10 omalla turvalla. Kuitenkin koska kone oli jo ollut kauan haavoittuneena päätin asentaa siihen uudestaan windowsin. Kaveri halusi vielä Bitfdefenderin koska oli siitä maksanut vaikka harmitteli kun näytti olevan ilman sitä nopeampi. Noh pari päivää sitten oli saanut taas koneelleen tuon saman paskeen ja eilen ei Bitdefener toiminut ollenkaan jota vihdoin päätti siitä luopua ja siirtyä WIN10 omaan pysyvästi :D
On muuten aika iso tuo nopeuserokin miten sivut avautuu jne. Bitdefenderillä tosi hitaasti toimii verrattuna WIN10 omaan.
Mikä olis sellainen ohjelma joka ei ilman lupaa poista / blokkaa yhtään mitään? Ärsyttää F-secure joka tekee omiaan ja säädöt ainakin safe versiossa puutteelliset.
RageDaddy
Team R&T
Niinpä, kasperskyn free tekee ihan samaa.
Pertti Kosunen
ESET NOD32 on ollut hyvä false postivien kannalta, kaikkeen löytyy myös säädöt ja voi laittaa kysymään käyttäjältä mitä tehdään missäkin tilanteessa.
Avastissa myös voi säätää paljon asetuksia, myös ilmaisversiossa. Lisäksi voi valita mitä eri suojia asentaa. Vinkki: älä ikinä asenna defaulttina vaan valitse custom ja valitse haluamasi palikat. Iso osa "suojamoduuleista" on ihan hömppää.
Olipa hyvä että kurkkasin tänne. Yksi säikähtänyt Bitdefenderiläinen ilmottautuu, mietin jo että oonkohan jonkun paskan muka päästänyt läpi kun tämä oli "not responding" tilassa. Kertaalleen kerkesin jo uudestaan asentamaankin koko jutun ja vielä eilisiltana kenkkuili. Nyt töistä palattua tämä tuntui rauhottuneen kun lukaisi tätä triidiä + tuon bd:n foorumiviestit läpi
Sama täällä. Bitdefender "not responding" tilassa. Poistoon meni ja avast tilalle. Katsotaan uudemman kerran ku saavat toimimaan.
RageDaddy
Team R&T
Do dii, uutta mini pum pum konetta pykätty pystyyn jo hyvän aikaa. Stoppasi yllättäen taas tähän kohtaan, että mitäs laitetaan AV:ksi. Hetkinen meni penkoessa, mutta löytyhän se. Joku oli tuota Bullguardia kokeillut ja tykästynyt, niin siihen saa täysin legit 365 päivän lisenssin. Sivu venäjäksi, mutta lataa linkistä Bullguard internet security 2018, asenna ja tärkein kohta! REKISTERÖIDY millä tahansa emaililla (toimivalla oletan?) ja Bada Bing Bada Bum 365 päivän legit lisenssi. Tässähän tulee mukana kaikenlaista hauskaa. CCleanerin voi unohtaa kö tässä automaaginen vastaava ja muuta huikeeta. Ei ole kusetus eikä mikään pöpö. Löydetty täältä:
List of Legit Daily Giveaways sites (Contributed by MT Members)
ja ryssämongerruksesta löytyy.
Kiitokse taivaan isälle ja pojalle @Jesus :smoke:
BullGuard Internet Security на 1 год бесплатно
Edit. AV-comparahötön testeissä marraskuussa 2017 100% pöpöjä pataan ja 0 falsea, elikkäs ei paremmin voi enää vetää, mutta ton antivirusasiantuntijapihvin mielestä varmaan ihan paska taas tämäkin?
AV-Comparatives - Independent Tests of Anti-Virus Software - Real World Protection Test Overview
Edit2. Hienosti vetää full scannin läpi tasan 3:38 minuutissa mikä nyt ei varsinaisesti ole nykyään enää erityisen nopeasti (etenkin kun just asennettu winpaske), mutta kaikkia ytimiä lääpii 60-70% tuntumalla ja noita multithred av-paskeita en ole vielä kovin montaa tavannut? Semmosia kyllä jotka vetää kaikki 100% ja mitään et koneella voi tehdä samaan aikaan tai semmosia mitkä vetää yhden langan solmuun ja melkein sama homma.
16 minuutin käytön jälkeen voi todeta että voi veljet mikä löytö :rofl:
Tämä kyllä pitää ottaa testiin kun kotia pääsen. Kiitokset!
Rohkeutta löytyy joltain "ryssämongerrus" sivulta ladata eikä suoraan valmistajan sivuilta. Vähän outoa kun niin kiihkeästi näitä AV-juttuja tänne päivittelet.
Huoh, täällä on kyllä monta kertaa todettu, että kannattaa katsoa niitä tuloksia pidemmältä ajalta eikä vain yhtä tulosta, oli se sitten viimeisin tai ei. Bullguardin 2017 tulokset pomppivat 1-15 sijan välillä, eli sinne about keskikastiin menee, eipä siinä mitään vikaa, itselläkin käytössä AV joka on keskikastissa. Viimeinen performance testikin oli oikein hyvällä mallilla.
Mutta veikkanpa, että sinä vielä tulet taas hetken päästä tänne takaisin meuhkaamaan näistä AV:sta. Oletko jo käynyt kaikki AV:t läpi? Sen verran usein ja tietyin väliajoin täällä käyt parjaamassa jotain AV:ta ja hehkuttamassa toista. :D Käyhän tuo harrastuksesta..
RageDaddy
Team R&T
Niin no jos lataa valmistajan sivuilta, maksaa vuoden lisenssi 59,95€ ( BullGuard Internet Security 2018 for Windows MAC and Android ) ja jos ryssämongerrukselta mikä on yhden arvostetuimman tietoturvasivuston suosittelema moderaattorin v.2014 nostamassa topicissa: List of LEGIT Daily GIVEAWAYS sites niin ei voi mitään? Talonpoikaistuulipukulogiikallakin pitäisi jonkin neuronin hokata, että GIVEAWAYS vois olla ilmainen ja kyllä, näille tietoturvasivujen käyttäjille jaetaan ilmaisia softia, uskomatonta..eikö totta. Luonnollisesti lämmäsin ladatun tiedoston oitis virustotaaliin ja puhdas oli, ihme kyllä.
Että mitä tähän nyt sit enää vois sanoa, ei vissiin mitään? Olen käynyt varmaan kaikki AV:t läpi, harrastus saatana sekin on! Onpahan jotain pohjia millä huudella, toisin kuin eräillä mitkä LUKEVAT jonkin softan toiminnasta yms :vihellys:
Edit. Ja jos suurennoslasilla niin ei näitä mun juttuja YK:llakaan kannata ihan tosissaan ottaa :happy:
237 401
allun90
