MEMORY MODULE |
MANUFACTURER |
Crucial Technology |
SERIES |
Ballistix RGB Black |
PART NUMBER |
BL8G36C16U4BL.M8FE1 |
SERIAL NUMBER |
E607F19Ah |
JEDEC DIMM LABEL |
8GB 1Rx8 PC4-2666V-UA2-11 |
ARCHITECTURE |
DDR4 SDRAM UDIMM |
SPEED GRADE |
DDR4-2666V |
CAPACITY |
8 GB (8 components) |
ORGANIZATION |
1024M x64 (1 rank) |
REGISTER MODEL |
N/A |
MANUFACTURING DATE |
August 23-27 / Week 34, 2021 |
MANUFACTURING LOCATION |
Boise, USA (SIG) |
REVISION / RAW CARD |
0000h / A2 (8 layers) |
DRAM COMPONENTS |
MANUFACTURER |
Micron Technology |
PART NUMBER |
C9BLM (CT40A1G8SA-045M:E) |
PACKAGE |
Standard Monolithic 78-ball FBGA |
DIE DENSITY / COUNT |
8 Gb E-die (Z11B / 19 nm) / 1 die |
COMPOSITION |
1024Mb x8 (64Mb x8 x 16 banks) |
INPUT CLOCK FREQUENCY |
1333 MHz (0,750 ns) |
MINIMUM TIMING DELAYS |
19-19-19-43-62 |
READ LATENCIES SUPPORTED |
20T, 19T, 18T, 17T, 16T, 15T, 14T... |
SUPPLY VOLTAGE |
1,20 V |
XMP CERTIFIED |
1802 MHz / 16-18-18-38-58 / 1,35 V |
XMP EXTREME |
Not programmed |
SPD REVISION |
1.1 / September 2015 |
XMP REVISION |
2.0 / December 2013 |
FREQUENCY | CAS | RCD | RP | RAS | RC | FAW | RRDS | RRDL | WR | WTRS |
1333 MHz | 20 | 19 | 19 | 43 | 62 | 28 | 4 | 7 | 20 | 4 |
1333 MHz | 19 | 19 | 19 | 43 | 62 | 28 | 4 | 7 | 20 | 4 |
1200 MHz | 18 | 18 | 18 | 39 | 56 | 26 | 4 | 6 | 18 | 3 |
1067 MHz | 17 | 16 | 16 | 35 | 50 | 23 | 4 | 6 | 16 | 3 |
1067 MHz | 16 | 16 | 16 | 35 | 50 | 23 | 4 | 6 | 16 | 3 |
933 MHz | 15 | 14 | 14 | 30 | 44 | 20 | 3 | 5 | 14 | 3 |
933 MHz | 14 | 14 | 14 | 30 | 44 | 20 | 3 | 5 | 14 | 3 |
800 MHz | 13 | 12 | 12 | 26 | 37 | 17 | 3 | 4 | 12 | 2 |
800 MHz | 12 | 12 | 12 | 26 | 37 | 17 | 3 | 4 | 12 | 2 |
667 MHz | 10 | 10 | 10 | 22 | 31 | 14 | 2 | 4 | 10 | 2 |
1802 MHz | 16 | 18 | 18 | 38 | 58 | 38 | 6 | 9 |
