- Liittynyt
- 18.10.2016
- Viestejä
- 1 077
Elikkä on samanlainen topikki missä on ssd levyjen tuloksia, niin miks ei vielä ollut hdd.
Ja nyttemmin olisi tarvetta nopeammille kintolevyille mitä WD RED tarjoaa ja ei ole aikaa odotella multi aktuator kovoja.
Tässä oma tulos WD RED 4TB. Josko jollain löytyisi postata seagate barracuda pro ja ironwolf kiintolevyjen nopeuksia.
Huom. ei raideja.
Edit: Lisätty WDC HGST Ultrastar He10 8TB
Lisätty toinen WDC HGST Ultrastar He10 8TB
![wdred_4tb_2_full.png wdred_4tb_2_full.png](https://bbs.io-tech.fi/data/attachments/251/251372-1f24123f23a04fee1ad2b2e4d5ab81d1.jpg)
Huom. ei raideja.
Koodi:
smartctl 7.0 2018-12-30 r4883 [x86_64-w64-mingw32-w10-b18362] (sf-7.0-1)
Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: WDC HGST Ultrastar He10
Device Model: WDC WD80EMAZ-00WJTA0
Serial Number:
LU WWN Device Id:
Firmware Version: 83.H0A83
User Capacity: 8 001 563 222 016 bytes [8,00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Thu Jul 11 17:22:53 2019
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is: Unavailable
APM level is: 164 (intermediate level without standby)
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, frozen [SEC2]
Wt Cache Reorder: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x80) Offline data collection activity
was never started.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 93) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 927) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate PO-R-- 100 100 016 - 0
2 Throughput_Performance --S--- 100 100 054 - 0
3 Spin_Up_Time POS--- 100 100 024 - 0
4 Start_Stop_Count -O--C- 100 100 000 - 5
5 Reallocated_Sector_Ct PO--CK 100 100 005 - 0
7 Seek_Error_Rate -O-R-- 100 100 067 - 0
8 Seek_Time_Performance --S--- 100 100 020 - 0
9 Power_On_Hours -O--C- 100 100 000 - 0
10 Spin_Retry_Count -O--C- 100 100 060 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 5
22 Helium_Level PO---K 100 100 025 - 100
192 Power-Off_Retract_Count -O--CK 100 100 000 - 5
193 Load_Cycle_Count -O--C- 100 100 000 - 5
194 Temperature_Celsius -O---- 196 196 000 - 33 (Min/Max 25/33)
196 Reallocated_Event_Count -O--CK 100 100 000 - 0
197 Current_Pending_Sector -O---K 100 100 000 - 0
198 Offline_Uncorrectable ---R-- 100 100 000 - 0
199 UDMA_CRC_Error_Count -O-R-- 200 200 000 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 1 Comprehensive SMART error log
0x03 GPL R/O 1 Ext. Comprehensive SMART error log
0x04 GPL R/O 256 Device Statistics log
0x04 SL R/O 255 Device Statistics log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x08 GPL R/O 2 Power Conditions log
0x09 SL R/W 1 Selective self-test log
0x0c GPL R/O 5501 Pending Defects log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x12 GPL R/O 1 SATA NCQ Non-Data log
0x13 GPL R/O 1 SATA NCQ Send and Receive log
0x15 GPL R/W 1 Rebuild Assist log
0x21 GPL R/O 1 Write stream error log
0x22 GPL R/O 1 Read stream error log
0x24 GPL R/O 256 Current Device Internal Status Data log
0x25 GPL R/O 256 Saved Device Internal Status Data log
0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (1 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
SCT Status Version: 3
SCT Version (vendor specific): 256 (0x0100)
Device State: Active (0)
Current Temperature: 33 Celsius
Power Cycle Min/Max Temperature: 26/33 Celsius
Lifetime Min/Max Temperature: 25/33 Celsius
Under/Over Temperature Limit Count: 0/0
SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 1 minute
Min/Max recommended Temperature: 0/65 Celsius
Min/Max Temperature Limit: -40/70 Celsius
Temperature History Size (Index): 128 (30)
Index Estimated Time Temperature Celsius
31 2019-07-11 15:15 0 -
... ..( 95 skipped). .. -
127 2019-07-11 16:51 0 -
0 2019-07-11 16:52 28 *********
1 2019-07-11 16:53 26 *******
2 2019-07-11 16:54 26 *******
3 2019-07-11 16:55 26 *******
4 2019-07-11 16:56 27 ********
5 2019-07-11 16:57 27 ********
6 2019-07-11 16:58 28 *********
7 2019-07-11 16:59 28 *********
8 2019-07-11 17:00 29 **********
9 2019-07-11 17:01 29 **********
10 2019-07-11 17:02 30 ***********
11 2019-07-11 17:03 30 ***********
12 2019-07-11 17:04 30 ***********
13 2019-07-11 17:05 31 ************
... ..( 2 skipped). .. ************
16 2019-07-11 17:08 31 ************
17 2019-07-11 17:09 32 *************
... ..( 4 skipped). .. *************
22 2019-07-11 17:14 32 *************
23 2019-07-11 17:15 33 **************
... ..( 5 skipped). .. **************
29 2019-07-11 17:21 33 **************
30 2019-07-11 17:22 0 -
SCT Error Recovery Control:
Read: 70 (7,0 seconds)
Write: 70 (7,0 seconds)
Device Statistics (GP Log 0x04)
Page Offset Size Value Flags Description
0x01 ===== = = === == General Statistics (rev 1) ==
0x01 0x008 4 5 --- Lifetime Power-On Resets
0x01 0x010 4 0 --- Power-on Hours
0x01 0x018 6 795327 --- Logical Sectors Written
0x01 0x020 6 7051 --- Number of Write Commands
0x01 0x028 6 280834326 --- Logical Sectors Read
0x01 0x030 6 1104119 --- Number of Read Commands
0x01 0x038 6 --- Date and Time TimeStamp
0x03 ===== = = === == Rotating Media Statistics (rev 1) ==
0x03 0x008 4 0 --- Spindle Motor Power-on Hours
0x03 0x010 4 0 --- Head Flying Hours
0x03 0x018 4 5 --- Head Load Events
0x03 0x020 4 0 --- Number of Reallocated Logical Sectors
0x03 0x028 4 0 --- Read Recovery Attempts
0x03 0x030 4 0 --- Number of Mechanical Start Failures
0x04 ===== = = === == General Errors Statistics (rev 1) ==
0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors
0x04 0x010 4 0 --- Resets Between Cmd Acceptance and Completion
0x05 ===== = = === == Temperature Statistics (rev 1) ==
0x05 0x008 1 33 --- Current Temperature
0x05 0x010 1 - N-- Average Short Term Temperature
0x05 0x018 1 - N-- Average Long Term Temperature
0x05 0x020 1 33 --- Highest Temperature
0x05 0x028 1 25 --- Lowest Temperature
0x05 0x030 1 - N-- Highest Average Short Term Temperature
0x05 0x038 1 - N-- Lowest Average Short Term Temperature
0x05 0x040 1 - N-- Highest Average Long Term Temperature
0x05 0x048 1 - N-- Lowest Average Long Term Temperature
0x05 0x050 4 0 --- Time in Over-Temperature
0x05 0x058 1 65 --- Specified Maximum Operating Temperature
0x05 0x060 4 0 --- Time in Under-Temperature
0x05 0x068 1 0 --- Specified Minimum Operating Temperature
0x06 ===== = = === == Transport Statistics (rev 1) ==
0x06 0x008 4 3 --- Number of Hardware Resets
0x06 0x010 4 0 --- Number of ASR Events
0x06 0x018 4 0 --- Number of Interface CRC Errors
0xff ===== = = === == Vendor Specific Statistics (rev 1) ==
|||_ C monitored condition met
||__ D supports DSN
|___ N normalized value
Pending Defects log (GP Log 0x0c)
No Defects Logged
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 2 0 Command failed due to ICRC error
0x0002 2 0 R_ERR response for data FIS
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0005 2 0 R_ERR response for non-data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
0x0008 2 0 Device-to-host non-data FIS retries
0x0009 2 2 Transition from drive PhyRdy to drive PhyNRdy
0x000a 2 3 Device-to-host register FISes sent due to a COMRESET
0x000b 2 0 CRC errors within host-to-device FIS
0x000d 2 0 Non-CRC errors within host-to-device FIS
Type <return> to exit:
Koodi:
smartctl 7.1 2019-12-30 r5022 [x86_64-w64-mingw32-w10-1809] (sf-7.1-1)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
Serial Number:
LU WWN Device Id: 5 000cca 267d4fbdd
Local Time is: Sun Mar 08 15:45:00 2020
was never started.
been run.
command.
power-saving mode.
recommended polling time: ( 901) minutes.
2 Throughput_Performance --S--- 130 130 054 - 108
4 Start_Stop_Count -O--C- 100 100 000 - 6
8 Seek_Time_Performance --S--- 128 128 020 - 18
9 Power_On_Hours -O--C- 100 100 000 - 34
12 Power_Cycle_Count -O--CK 100 100 000 - 6
192 Power-Off_Retract_Count -O--CK 100 100 000 - 7
193 Load_Cycle_Count -O--C- 100 100 000 - 7
194 Temperature_Celsius -O---- 185 185 000 - 35 (Min/Max 23/35)
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
No Errors Logged
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 1 -
# 2 Short offline Completed without error 00% 1 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Current Temperature: 35 Celsius
Power Cycle Min/Max Temperature: 32/35 Celsius
Lifetime Min/Max Temperature: 23/35 Celsius
Temperature History Size (Index): 128 (37)
38 2020-03-08 13:38 32 *************
... ..( 2 skipped). .. *************
41 2020-03-08 13:41 32 *************
42 2020-03-08 13:42 31 ************
... ..( 9 skipped). .. ************
52 2020-03-08 13:52 31 ************
53 2020-03-08 13:53 30 ***********
... ..( 40 skipped). .. ***********
94 2020-03-08 14:34 30 ***********
95 2020-03-08 14:35 25 ******
96 2020-03-08 14:36 25 ******
97 2020-03-08 14:37 26 *******
98 2020-03-08 14:38 26 *******
99 2020-03-08 14:39 27 ********
100 2020-03-08 14:40 28 *********
101 2020-03-08 14:41 28 *********
102 2020-03-08 14:42 29 **********
103 2020-03-08 14:43 29 **********
104 2020-03-08 14:44 30 ***********
105 2020-03-08 14:45 30 ***********
106 2020-03-08 14:46 31 ************
109 2020-03-08 14:49 31 ************
110 2020-03-08 14:50 32 *************
... ..( 8 skipped). .. *************
119 2020-03-08 14:59 32 *************
120 2020-03-08 15:00 33 **************
... ..( 8 skipped). .. **************
1 2020-03-08 15:09 33 **************
2 2020-03-08 15:10 34 ***************
... ..( 11 skipped). .. ***************
14 2020-03-08 15:22 34 ***************
15 2020-03-08 15:23 35 ****************
... ..( 20 skipped). .. ****************
36 2020-03-08 15:44 35 ****************
37 2020-03-08 15:45 32 *************
0x01 0x008 4 6 --- Lifetime Power-On Resets
0x01 0x010 4 34 --- Power-on Hours
0x01 0x018 6 16607477510 --- Logical Sectors Written
0x01 0x020 6 65272201 --- Number of Write Commands
0x01 0x028 6 16335652527 --- Logical Sectors Read
0x01 0x030 6 64302635 --- Number of Read Commands
0x03 0x008 4 32 --- Spindle Motor Power-on Hours
0x03 0x010 4 32 --- Head Flying Hours
0x03 0x018 4 7 --- Head Load Events
0x05 0x008 1 35 --- Current Temperature
0x05 0x010 1 31 N-- Average Short Term Temperature
0x05 0x020 1 35 --- Highest Temperature
0x05 0x028 1 23 --- Lowest Temperature
0x05 0x030 1 31 N-- Highest Average Short Term Temperature
0x05 0x038 1 24 N-- Lowest Average Short Term Temperature
0x06 0x010 4 4 --- Number of ASR Events
||__ D supports DSN
No Defects Logged
0x0009 2 3 Transition from drive PhyRdy to drive PhyNRdy
![wdred.png wdred.png](https://bbs.io-tech.fi/data/attachments/141/141017-11d94e5a0fa709eaab506d86f13a49b2.jpg)
![WD HELIUM ATTO – kopio.png WD HELIUM ATTO – kopio.png](https://bbs.io-tech.fi/data/attachments/248/248699-aa72c9f4b787bf99f7ae6cb4e8985a47.jpg)
66,1 KB Katsottu: 8
