Rusna
Make ATK Great Again
- Liittynyt
- 18.10.2016
- Viestejä
- 2 313
Tulevan Intel NUC:n (Apollo Lake) tekniset tiedot on julkaistu Intelin toimesta:
Alkuperäinen lähde: linkki
Henkilökohtaisesti näen tässä vihdoin pätevän HTPC-laitteen joka tukee mm. HDMI2.0. Hankintaan menee!
- CPU: Intel Celeron J3455 CPU, quad-core, 1.5 GHz (2.3 GHz burst), 10W TDPGPU: Intel HD Graphics 500, 12 EUs, 250 MHz base frequency, up to 750 MHz
- Memory: Up to 8 gigabytes of DDR3L-1866, 1.35 V, two slots for dual-channel mode
- USB: 2 front USB 3.0 ports (one with fast charging), 2 rear USB 3.0 ports
- 2.5″ SATA slot: Single slot for a 2.5″ SATA SSD or HDD drive, max. height 9.5 mm
- Display connectivity: Full-size HDMI 2.0 port (uses MegaChips MCDP2800-BCT LSPCon) including HDMI CEC support, VGA portAudio connectivity: 7.1 channel digital audio over HDMI, 3.5 mm headphone jack in front panel, 3.5 mm speaker/TOSLink connector in the rear panel
- Networking: Gigabit Ethernet (Realtek 8111HN), 802.11ac m.2 2230-size WiFi card preinstalled, Bluetooth 4.2
- Infrared: Infrared receiver in the front panel
- Microphone: Digital microphone array (DMIC), two microphones in the front panel
