- Liittynyt
- 14.10.2016
- Viestejä
- 21 879
DRIVER VERSION: 31.0.101.4672 Non-WHQL
DATE: September 3, 2023
• Graphics Driver package has temporarily increased to significantly reduce the Starfield* game load duration.
• Several Starfield* game instability and visual artifacts have been fixed in this driver. High Preset and below is
recommended to improve stability.
• Efforts in progress to further improve overall gaming experience of Starfield* for Intel® Arc™ users in future
driver updates.
GAMING HIGHLIGHTS:
Intel® Game On Driver support on Intel® Arc™ A-series Graphics for:
• SYNCED*
FIXED ISSUES:
Intel® Arc™ Graphics Products:
• Starfield* (DX12) Game load duration is significantly reduced.
• Starfield* (DX12) may experience instability and application crash while launching and during gameplay.
• Starfield* (DX12) may exhibit texture corruptions and scene flickers during gameplay.
KNOWN ISSUES:
• Starfield* (DX12) may experience application instability in some areas of the game.
• Starfield* (DX12) may exhibit corruption when using Dynamic Resolution Scaling. A workaround is to change
the Render Resolution Scale slider value.
• Starfield* (DX12) may exhibit texture flickering on light sources during gameplay.
• Starfield* (DX12) may exhibit low texture details on certain objects in the game.
• UNCHARTED: Legacy of Thieves Collection* (DX12) may exhibit texture corruption on characters.
• Halo Infinite* (DX12) campaign may experience an application crash on some system configurations.
• Dead by Daylight* (DX11) may experience an application crash during gameplay.
• Topaz Video AI* may experience errors when using some models for video enhancement.
• Adobe After Effects* may experience an application crash during render operations.
• Device fan may ramp up frequently on certain Intel® Arc™ Graphics products.
Intel® Iris™ Xe MAX Graphics Products:
• Driver installation may not complete successfully on certain notebook systems with both Intel® Iris™ Xe + Iris™
Xe MAX devices. A system reboot and re-installation of the graphics driver may be required for successful
installation.
INTEL® ARC™ CONTROL KNOWN ISSUES:
• Using Arc Control Studio capture with certain games may incorrectly generate multiple video files.
• The “Connector” type in the Display page may incorrectly show DP* when using an HDMI* display connection.
• May observe “stream has already ended” pop-up after the power events with Capture/Highlights/Broadcast
toggle on.
• Performance Graphs may scale incorrectly after waking up from sleep.
Intel® Arc™ Control Performance Tuning (BETA):
• Intel® Arc™ Control Performance Tuning is currently in Beta. As such, performance and features may behave
unexpectedly. Intel® will continue to refine the Performance Tuning software in future releases.
Lähde: Intel® Arc™ & Iris® Xe Graphics - Windows*
