Myydään Cable Matters 48Gbps Unidirectional USB C to HDMI 2.1 Adapter for macOS, Supports 8K@60Hz / 4K@240Hz HDR - Ylivieska
Tuote: Cable Matters 48Gbps Unidirectional USB C to HDMI 2.1 Adapter for macOS, Supports 8K@60Hz / 4K@240Hz HDR
Hinta:30
Tuote ostettu (mistä ja milloin):Amazon 14.6.2026
Kuitti löytyy (takuu voimassa):kuitti mukaan
Muuta huomioitavaa:toimii niinkuin pitää, ei käytönjälkiä
Tällä saa vanhemmista maceista 4k 120hz signaalin monitoriin tai telkkariin hdmin kautta usb-c portista, pitäs toimia myös pceellä.
  • Certified USB-C to HDMI 2.1 Adapter: Upgrade to HDMI 2.1 or future-proof your setup with the Cable Matters USB C to HDMI 2.1 Adapter; HDMI to USB C cable adapter combines the latest HDMI 2.1 standard with the versatility of USB-C; The HDMI USB C adapter (USB C adapter to HDMI) supports up to 8K 60Hz resolution on compatible displays and devices; HDMI to Type C adapter is perfect for ultra high resolution displays
  • Stunning 8K@60Hz / 4K@240Hz Resolution: Connect 8K or 4K 240 Hz gaming monitors and TVs to laptops, smartphones, tablets, and more with a USB HDMI adapter; USBC to HDMI adapter (USB-C to HDMI adapter) supports a maximum video resolution of 8K 60Hz with RGB 4:4:4; Enjoy high-quality video with no loss in picture quality with the Thunderbolt 3 / Thunderbolt 4 to HDMI adapter
  • Vivid Video Experience: The 8K HDMI to Thunderbolt adapter supports USB-C devices with DP Alt Mode support; Thunderbolt to HDMI adapter is Thunderbolt 5/4/3 port compatible; USB-C adapter supports HDR for breathtaking colors; Auto Low Latency Mode (ALLM) support for lag-free gaming with the HDMI to USBC adapter; Enjoy surround sound audio for lifelike sound with the USB C HDMI adapter
  • Wide Compatibility: Take advantage of 8K resolution support on a newer desktop computer or laptop like Lenovo, DELL XPS with the Mac Thunderbolt 4 to HDMI adapter; The USB C HDMI cable is compatible with newer Nvidia RTX 3000 series and AMD Radeon RX6000 series graphics cards or USB4 (USB 4) and Thunderbolt 4 port on a laptop with 11th generation Intel Tiger Lake CPU and Intel Iris Xe graphics or later versions; 8K video is compatible with Intel Evo laptops using the USB Type C to HDMI adapter
  • Innovative and Durable Design: Premium construction of the HDMI to Thunderbolt 4 adapter features a premium braided cable for durability and prevents fraying; Metal connectors and aluminum enclosure of the USB-C HDMI adapter provide a premium look and feel and improve the performance of the HDMI 2.1 to USB C adapter
Paikkakunta (ilmoita myös otsikossa ja tagissa):Ylivieska
Toimitustapa:nouto, posti
Maksutapa:mobilepay, käteinen
allupukki
