- Liittynyt
- 14.10.2016
- Viestejä
- 22 211
Toistaiseksi ei ole tietoa, miksi AMD on rajoittanut viimeiset ajurijulkaisut vain uusimmalle sukupolvelleen.
Fixed Issues
- Intermittent driver timeout may occur when applying Auto Overclock performance tuning.
- While playing Valheim™ an app crash or driver timeout may occur using Vulkan® API.
- While playing The Witcher® 3: Wild Hunt, an intermittent app crash or driver timeout may occur when Ray Tracing settings are enabled.
- Minor performance degradation may be observed after applying a factory reset of settings.
- High idle power has situationally been observed when using select high resolution and high refresh rate displays.
- Intermittent app crashes or driver timeout may occur when using Radeon Super Resolution with some extended display configurations.
- Video stuttering or performance drop may be observed during gameplay plus video playback with some extended display configurations.
- Stuttering may be observed in UNCHARTED™ 4: A Thief’s End during the opening game sequence.
- Some virtual reality games or apps may experience lower than expected performance.
